TB or IAC problem??
Old Aug 13, 2004 | 07:30 AM
350TPI5SPEED's Avatar
TB or IAC problem??
i swapped injectors yesterday and when i started it up it sounded supercharged. but its not. the noise was coming from the IAC. is it bad? ther is no ses light and it was fine before. btw its a bbk 58mm and ive had it on for 1100 miles wiithout the blower whine
Old Aug 13, 2004 | 08:33 AM
raul.garcia's Avatar
Re: TB or IAC problem??
If you suspect the IAC I would imagine that you're also having idle problems. Have someone turn the key to on/engine off while you listen for the IAC to position it's self.
When cold the ECM should shorten the pintle length to provide more air, when warm the ECM should lengthen the pintle to reduce air. If you can't measure any decernable difference in length hot, or cold, the IAC, or ECM, or anything in between is faulty.
If you have the time do the minumum air setting per factory procedure (baseline idle 400-450rpm, I think.)
If you need it I can email it to you, mine is an 88, but the procedure should be the same.
Old Aug 13, 2004 | 10:13 AM
can you email that to me. oh and im having a little idle problem. minor details
Old Aug 14, 2004 | 10:34 PM
ok replaced the iac and still sounds blown??? any ideas???
Old Aug 15, 2004 | 10:47 AM
aklim's Avatar
See if you can disassemble the housing and clean the TB at the same time.
Old Aug 16, 2004 | 11:39 AM
when i replaced the iac i cleaned it with carb cleaner. im not hearing anything from the iac when the key is turned.
Old Aug 17, 2004 | 11:53 PM
anyone???
Old Aug 19, 2004 | 06:49 AM
aklim's Avatar
Did you remove the housing and clean that and all the passages too?
You probably won't hear the IAC. What you need is a scantool to observe the IAC count when the car is running.
Old Aug 19, 2004 | 03:55 PM
RedIrocZ-28's Avatar
Did you forget to hook up the vacuum lines? Also, if you hear a whine check your alternator. I know mine started to sound like one when it was going bad.
Old Aug 19, 2004 | 11:46 PM
housing was cleaned with carb cleaner and my toothbrush. vacuum lines all hooked up. its not the alt. it is coming from the iac for sure. when ii put my finger over the passage it kinda stops
Old Aug 20, 2004 | 12:50 AM
Did you accidently crack the IAC housing? Or is the gasket maybe broken?
Sounds like a vacuum leak of some sort because there is nothing else but alternator or vacuum leak I have EVER heard from my motor that would sound like a blower whine. Get Carb Cleaner and spray it at the IAC when the motor is running... if the idle changes you found your problem.
Old Aug 21, 2004 | 01:05 AM
aklim's Avatar
If your finger is on the housing and it stops, which passage are we talking about?
Old Oct 2, 2004 | 02:52 PM
Pearl Z's Avatar
did you ever get that fixed? id like to know since i just bought it lol. i forgot to even ask if anything was wrong with the tb.....
Old Oct 5, 2004 | 04:35 PM
aklim's Avatar
Did you have the tube going from the TB to the air cleaner on when you heard this whine?
Old Oct 5, 2004 | 10:43 PM
yes and no i tried both
