taking off egr
Old Mar 20, 2004 | 08:39 PM
slow_roc's Avatar
taking off egr
i'm going from a 305 tpi to a 40 over 350 with vortec heads mild cam accell runners 52mm tb 24lb'ers and other lil stuff i didnt opt for the erg kit for the vortec's think i will have any issues leaveing it off ? should i get a custom chip burned ... if so were is a good place to have it done ?
thanx steve
Old Mar 20, 2004 | 09:41 PM
WhiteKid's Avatar
Re: taking off egr
thanx steve
If you take off the valve you might have Emissions problems with inspection. You will also most likely trigger the check engine light. Anyone else?
Old Mar 20, 2004 | 11:54 PM
trackbird's Avatar
Re: Re: taking off egr
Yep. He nailed it.
However, the auto cars, if running in "park" on the gear selector defeat the EGR. I found this out when doing research about what to do after swapping to a 5 speed. But, if you still have an auto and need reverse lights, you are stuck with a prom to defeat it.
Old Mar 21, 2004 | 01:30 AM
aklim's Avatar
I believe it will trip a code 32 EGR. To avoid that, you will need a custom EPROM
Old Mar 21, 2004 | 02:19 AM
slow_roc's Avatar
yeh my car is a auto and inspection isnt a prob lol already running no cats or smog is there any one that burns proms cuz it seems like alot to start doing it myself ... or is it ?
Old Mar 21, 2004 | 09:45 PM
aklim's Avatar
www.fasterproms.com will do a good job. They will burn it to your specs and then if you borrow their DIACOM program and load it onto a laptop, you can email them the readings and they can reburn it and reburn it till it gets right on to be a true custom chip. Lingenfelter will want your car for a week to get it custom because they also take readings based on road tests. Some will take readings and make adjustments based on dyno tests. Any other way of doing it is simply a SWAG.
Old Mar 21, 2004 | 09:57 PM
zrs's Avatar
zrs
Slow Roc, I am doing pretty much the same thing as you. I have a 357 engine (bored.040) 062 vortec heads, Hot cam w/ 1.6 rockers. The induction system I will be using is a TPI and am currently saving some $$ to get the SDPC vortec tpi manifold which has provisions for EGR vavle. Are you going to use the SDPC vortec manifold?
Old Mar 21, 2004 | 11:22 PM
slow_roc's Avatar
yeh i was wondering about drivablilty issues and if codes would set and about a custom prom fix those issues... and ... yeh zrs i have the sdpc base but u have to get a kit to get the actual exhaust gas up to the intake and modify your exhaust manifold or headers since the vortec heads dont have the erg ports on them i was planning on just putting plates over the erg (were the valve set) and the little place behind the runner i was thinkin about running the hot cam with 1.6 but got a slp 51004 cam with 1.5 roller tips for a really good deal so coudlnt complain
Old Mar 22, 2004 | 12:30 AM
zrs's Avatar
zrs
Looking forward when you get you car up running with the new setup.
Old Mar 22, 2004 | 05:13 PM
aklim's Avatar
You'd want a custom chip to take care of it and to optimize the system for the new upgrades so that should not be an issue.
Old Mar 22, 2004 | 05:48 PM
krazzycowgirl's Avatar
www.Fastchip.com is a good place as well. They also program to your specs & is $350 then you can take it anywhere & have someon dyno it & play with the chip.
Old Mar 22, 2004 | 06:44 PM
aklim's Avatar
www.fasterproms.com is also the same price. They can lend you datalogging software to put onto your laptop and you can email them results from home. That way, they can adjust it to be truely custom nd you can flog it on a deserted strech of road at night and go with that. No need for dyno fees. When it has reached it's final burn, you send them back the old chips and $350. Next time you do this again it will cost you $150 to get it dialed in. However, you will not be doing it again unless you have done some major mods.
aklim's Avatar
Noenav
Mar 1, 2019 07:38 AM
timmy39120
May 8, 2015 11:41 AM
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
Darth Xed
Jul 1, 2002 03:22 PM
