Finally changing rearends!
Old Mar 20, 2004 | 10:48 AM
Wishmaster's Avatar
Well I went ahead and got the 10 bolt 3.23 rearend non locking.....yeah it has drums on it but screw it......I was spending to much money driving around looking for a disc rear with the right gears..I mean I spent 40 bucks yesterday just driving to go see that 9 bolt and it was only a 2.77 rear and it would have costed to much to get a carrier and gears for that since they are hard to find....
so I'll just put an SLP posi unit in this and better gears and be done with it....
Now my delema is what gears do I want? 3.42 or 3.73?
For my mods what would be the better gear? 3.23, 3.42 or 3.73?
The car is a daily driver in the summer and sometimes a highway traveler going on trips to Florida and AL...
Can someone point me to the bearing kit that I will need?
Old Mar 20, 2004 | 12:20 PM
Rice Killer87's Avatar
being a TPI car,id go 3.42...dont go 3.73. but since u use it as a driver for those long trips...its almost better to go 3.23 unless u can stand to loss a little less gas mileage as w/ the 3.42's. i dont think there would be a big difference in change of gas mileage,but the choice is yours.
hope thats helps
Old Mar 20, 2004 | 03:07 PM
lordmetalz28's Avatar
i thought about it this way. my cars not to radical now. but in the future i plan on making it more extreme so i figured what the hell let me put the 3.73 in there i fi ever need it itll be in there. i also want an a$$load or torque so thats what i picked. really all depends on what your going to be doing with it in the future. i only really drive my car 3000 miles from may-october the one long highway trip i go on is 150 miles each way all highway to english town.
Old Mar 20, 2004 | 03:36 PM
Marc 85Z28's Avatar
Re: Finally changing rearends!
Are you sure this rear has 28 spline axles?
Old Mar 20, 2004 | 03:45 PM
i think even if it isnt slp sells 28 spline axels for it for the 3rd gen for 300bucks
Old Mar 20, 2004 | 05:49 PM
Wishmaster's Avatar
I thought 90 to 92 all came with the 28 spline axles?
THIS REaR BETTER HAVE THE 28's.....I went on advice from reading the boards. sez all 90-92 came with 28......change over year was 89.
If it doesnt then I taking it back to the junk yard.
Bad thing is Ive cleaned it, painted it, and removed all the old shoes and hardware and drained the grease... cause im going to replace all that with new stuff.
But just like my current rearend I cant get the locking bolt off to pull the axles...Im waitign on my neighbor to get home so he can tig weld a wrnech to it just like I had to do last time when I changed a leaking axles seal.
Old Mar 20, 2004 | 06:15 PM
Wishmaster's Avatar
Re: Re: Finally changing rearends!
I figured out a way to get the lock bolt out....
pulled axles and counted the splines...and THANK GOD...I got 28's.....whew!
Old Mar 21, 2004 | 07:44 AM
Marc 85Z28's Avatar
Good, then the SLP Torsen unit will work. I was worried that you might have bought an early 26 spline unit and wanted to put the SLP unit in. In that case the 9 bolt would have been cheaper. Looks like you did your homework
Old Mar 21, 2004 | 08:00 AM
Wishmaster's Avatar
how do you figure that? the 9 only hd 2.77 gears in it. I would have had to buy a carrier and gears for that.
Old Mar 21, 2004 | 09:38 AM
kevin 2.8's Avatar
started at 73,000 on the clock, i put 45,000 on my car the first year i had it and i only worked a 1/2 year.
glad its 2.73 and almost glad v6
Old Mar 21, 2004 | 10:49 AM
Wishmaster's Avatar
LOL!...and your point is?
keep the 2.73's? heck no!.....I want some pull to this car!
I dont wanna be all show and no go!...I want atleast some GO!
Im mostly all show at it stands now..
Old Mar 21, 2004 | 01:43 PM
Marc 85Z28's Avatar
DP
Old Mar 21, 2004 | 01:45 PM
Marc 85Z28's Avatar
In the last year alone I've seen at least 3-4 9 bolts, with 3.45 gears, a good posi, and brakes go for around $500-$600.
If the rear had been 26 spline, you'd be paying for the rear, 28 spline axles, the SLP unit, the gears and install kit, and the labor to set up the rear. That's well over $500
Old Mar 21, 2004 | 03:12 PM
Wishmaster's Avatar
oh I see!......yeah that would have sucked but thank god I have the 28's.....it should run me about 350-400 tops when Im done...but it will still be drum brakes but thats ok with me......
for now! LOL........
Old Mar 21, 2004 | 04:17 PM
how did you get the locking nuts off?
