Taking off the door panel
Old Oct 20, 2004 | 09:17 PM
Bruticus's Avatar
Hey all just a quick question i was trying to take off the oanels on my door i just couldnt get the top part of it off where the window is. Any ideas of how to take it off i tried wiggeling it but I dont wannt take a chance of breaking it. Thanks in advance.
Old Oct 20, 2004 | 09:38 PM
quickchicken's Avatar
Re: Taking off the door panel
try sliding the plastic rail side to side just a bit while mildly lifting or push down a tad, curl the plastic out towards the outer door just a bit and then pull up.
work with it , you wont break anything unless you start using simi monster force.
Old Oct 20, 2004 | 11:38 PM
Bruticus's Avatar
Ok sounds reasonable I just dont wanna break it thats the whole point.
Old Oct 21, 2004 | 01:32 AM
GearBreath's Avatar
Keeping the door panel as close to the door as possible, push with the heel of your hand on the plastic part at the top ******d (towards the outside of the car) and up. The window must be all the way down to get the panel off.
Good luck
Troy
So Cal
Old Nov 15, 2004 | 06:05 PM
Irieman's Avatar
I'm trying to remove a door panel on a 94 T/A. I'm also having problems removing the panel. I've removed four screws (two small and two large) from the passanger side panel...should there be anymore screws? Thanks
birdblack
Apr 20, 2015 04:24 PM
cmyname1
Feb 19, 2015 08:38 PM
Brake_L8
Jan 20, 2015 09:44 AM
siguy
Nov 27, 2014 10:07 AM
MilkyClr69
Jul 29, 2002 10:01 AM
