t-top compatibility
Old Apr 15, 2004 | 05:29 PM
kevin 2.8's Avatar
t-top compatibility
went to the wreckers today they had 3 firebirds/trans ams all with t-tops still in them
will firebird t-tops fit a camaro? and how do i tell what kind they are. ie the fastener type? glass/lexan? peg/post? i think. and what do i look for to tell if they are any good?
Old Apr 15, 2004 | 05:56 PM
krazzycowgirl's Avatar
Ok most firebird/camaro t-tops fit on both cars.
82-83 Fbody T-tops have a pin
84-92 have a hook.
Old Apr 15, 2004 | 06:56 PM
kevin 2.8's Avatar
what do i look for whn buying them? that the lock works, does the seal have to be good around the t-top itself?
Old Apr 15, 2004 | 07:37 PM
TheGreatJ's Avatar
I believe she's backwards on the years. 82-83 should be hook and 84 up should be pin. Camaro and Firebird are 100% compatible. You'll be able to tell glass from Lexan by the weight...glass tops are MUCH heavier.
Old Apr 15, 2004 | 08:30 PM
Stephen 87 IROC's Avatar
I put some Lexan T-tops from a 89 Formula into my 87 Camaro. The weight savings was around 5 pounds each. I took them apart and changed the locks around so I could still use my key to lock them.
Old Apr 15, 2004 | 08:41 PM
TheGreatJ's Avatar
I have 2 sets of tops....glass because they look much better and Lexan for weight reduction while racing.
Old Apr 15, 2004 | 08:56 PM
OK Ok I got it back wards lol What do I know I am a woman right?
Old Apr 16, 2004 | 08:53 AM
ws6transam's Avatar
Something else to consider is that the lexan tops use a large diameter locking pin whereas the glass ones use a small diameter locking pin. At least, that's my experience based on my having a 1984 T-top car. I bought some 1991 lexan T-tops and couldn't install them because the locking pin was too large to fit my car's pin sockets. I still haven't gotten the bigger diameter pin sockets, so the lexan tops sit downstairs instead of on my car.
HibachiZ28
Nov 6, 2015 12:53 AM
Z Power
Sep 19, 2015 11:19 PM
WPHIG2
Aug 27, 2015 06:37 AM
TGGodfrey
Aug 17, 2015 08:43 PM
