T-5 grinds into reverse???
Old Apr 17, 2003 | 08:36 AM
Black6SpdTA's Avatar
Every time i go to back up and shift to reverse, clutch all the way down and my tranny grinds real bad. i know another guy with this same problem. is it common? whats wrong
Old Apr 17, 2003 | 12:08 PM
Smooothie119's Avatar
Wink
As far as I know, everyone with a T-5 has this problem, myself included. Its actually kind of annoying to cuz it makes u look like u dont know how to drive stick, especially in public places where it attracts attention. Anyhow, everyone that I've talked to said its because of the fact that reverse doesnt have a synchro. I'm guessing that these trannys must not line up good inside with age cuz mine grinds alot more than it used to. Sometimes it can be minimized if you try shifting into 3rd, then 2nd, and then trying to hit reverse. If anyone else has any info to offer, I'd liove to hear it.
Old Apr 17, 2003 | 12:11 PM
Buzzbomb's Avatar
Time for a 6 speed swap
Old Apr 17, 2003 | 12:46 PM
irocz8957's Avatar
you might wanna try tightening your clutch pedal because if it's loose it may seem like you have it in all the way but you may not!
Old Apr 17, 2003 | 01:04 PM
Intercepter's Avatar
A simple fix for this is to shift into a forward gear right before going into reverse. Stop shift into first, third or fifth and then shift to reverse. You will have no grinding. Hope this helps.
Old Apr 17, 2003 | 01:09 PM
yenkoz28's Avatar
Yep just shift into 1st then it should pop right into reverse. At least thats what I did to minimize the grind.
Old Apr 17, 2003 | 01:22 PM
already in the works my friend...itll just be like 7-8 months
thanks yall for the info...no more grinding, or not near as much anymore
Old Apr 17, 2003 | 02:57 PM
KagA152's Avatar
thats what i do, up into 5th and get a running start into reverse, works everytime
Old Apr 17, 2003 | 05:36 PM
Marc 85Z28's Avatar
Wait until you come to a full stop before shifting into reverse.
Old Apr 17, 2003 | 06:16 PM
Blnk782's Avatar
I had the same problem on my first car, an 87 300zx turbo, it always grinded a bit and sometimes wouldnt go into gear and then, i sit there reved the engine and everyone just looks at you cause your not moving. But the same trick applies i found when i put it in first then into reverse it didnt grind
Old Apr 17, 2003 | 08:34 PM
Zepher's Avatar
I had the same problem with my T5.
Forward gear and then reverse worked everytime for me too.
Old Apr 18, 2003 | 07:46 AM
irocz8957's Avatar
yeah i forgot to say shift through all the gear before putting into reverse that may help
Old Apr 18, 2003 | 09:40 AM
you said it was a loose clutch pedal! and all you have to do is go to a forward gear like everyone else said (i.e. 5th) then into reverse.
Old Apr 20, 2003 | 01:06 PM
IgorT.455/406's Avatar
Originally posted by robvas
Reverse isn't syncronized
YES, exactly. T5s don't have syncros in rev. Like everyone said, go fifth or fourth, then reverse. Once you get good at it, you go fast, it looks good too!
Old Apr 20, 2003 | 09:07 PM
ICEmanZ's Avatar
see for reverse there are no syncronizers, that's why you hear the grinding nose...
but i never heard of shifting right from a forward gear into reverse... i'll have to try that out
Formula Steve
Sep 19, 2023 08:31 AM
blac94Z
Nov 4, 2015 01:59 PM
Bxlt1
Sep 29, 2015 03:18 PM
4586
Sep 27, 2015 01:55 PM
