suggestions on how to make easy bolt on horse power for cheap
Old 03-07-2005, 12:58 PM
xTONYx's Avatar
Thumbs up suggestions on how to make easy bolt on horse power for cheap
i have an 88 iroc z with the 350, 5.7 liter tpi automatic tranmission and i'm looking to make some bolt on horse power for under 500$ hopfully up to 30-50 extra hp
xTONYx is offline
Old 03-07-2005, 04:50 PM
Rice Killer87's Avatar
Re: suggestions on how to make easy bolt on horse power for cheap
headers and an adjustable fuel pressure regulator.
i suggest Heddman shorty headers,but you have to buy there y-pipe as well ($100 extra). they are an awesome fit and good spark plug access.
Rice Killer87 is offline
Old 03-07-2005, 05:00 PM
85_305's Avatar
^Hey.. where do you get a y-pipe for the Heddman shorties? I cannot find one.
85_305 is offline
Old 03-07-2005, 05:24 PM
Patriot's Avatar
Correct me if I'm wrong people :
TBBP 5 hp
Port Plenum 5 hp
MAT relocater kit 5-10 hp
AFPR 5-10 hp
Air Foil 6 hp
K/N 3 hp
Lower Fan Temp Switch 5 hp
Headers 20-25 hp
Catback 10-15 hp
Pulleys 10 hp
Synthetic oil 1 hp
Purple Ice 1 hp
bump timing from 6* to 10*
Patriot is offline
Old 03-08-2005, 08:00 AM
teke184's Avatar
most of those seem good...
the pulley is a little high i think, probably more like 2-3hp and 10#s of torque
the amount you have for headers is a bit hopefull i think.
considering the engine is only making ~225hp i don't think you'd gain 35-40 hp from header and a catback.
maybe 25hp total for the 2
they will definatly help. but the less hp you are making, the less power you are gonna gain from the headers/exhaust.
i would also throw on a DIY ramair system on the TPI...i saw great gains on the highway with mine.
teke184 is offline
Old 03-08-2005, 08:44 AM
dennisbernalitaly's Avatar
I had fuel pres regulator, headers, cat back, and high flow cats. All combined with a pair of K&Ns and a gutted are box, (home made ram air). I didn't Dyno, but I can tell you I def felt it gain a lot more power. A lot more fun to drive and better fuel economy. As for that Y pipe stuff------ look for a custom exhaust place around where you live, they can make pipes that match up to your headers for less than that. I bought edelbrock shorties, 2 random tech cats, and allready had a flowmaster muffler, and had sub frame connectors (weld in). I brought all of this to a shop, and had them put it all in, taking note that the exhaust has to be built inboard so the connectors can fit, and they charged me 220 bucks, and it took them almost 9 hours, haha. It was worth it. Spend a bit more than 500 and it will make that thing really open up.
dennisbernalitaly is offline
Old 03-08-2005, 09:40 AM
Doc99SS's Avatar
I would install a dry nitrous kit and a AFPR. This would take you a bit over $500, but gain you a solid 75RWHp. Plumb the nitrous jets ahead of the MAF sensor. Adjust the AFPR upwards to make sure you are getting enough fuel at WOT when the nitrous comes on.
It took me about 2 hours to install the dry kit I have on my '99 Camaro SS.
Doc99SS is offline
Old 03-08-2005, 01:58 PM
91z28man's Avatar
New to the game, what exactly does that do, bumping the timing up.
91z28man is offline
Old 03-08-2005, 02:54 PM
Avoided Z28's Avatar
I would say invest your money in NOS wet kit that way you can gat a very safe 100 HP for about $500
And just for the record I sprayed 225HP before I ever hurt the motor and it was because my Alternator went out and fuel pressure dropped
Avoided Z28 is offline
Old 03-08-2005, 05:31 PM
xTONYx's Avatar
I was thinking on putting on a larger throttle body and a aftermarket MAF and full exhaust and definetly no NOS thanx for all the suggestions
xTONYx is offline
Old 03-08-2005, 06:52 PM
mako350Z28's Avatar
Bumping the timing should give the car a little more power, better throttle response, and better fuel economy.
mako350Z28 is offline
Old 03-08-2005, 07:18 PM
85_305's Avatar
^Whaaaat? Bumping the timing gives *better* fuel economy?? How does that work?
And what the hell is it w/ 1.6 rockers? What does the 1.6 stand for, and why is that number so special?
85_305 is offline
Old 03-08-2005, 07:38 PM
Doc99SS's Avatar
Well, I did not post that, but what is meant by bumping the timing from 6* to 10* is the static timing. The factory setting is 6* on our MAF cars. This static timing is additive to the timing called for in the timing table in the ECM, so you get 4* more timing across the board, even at WOT. And it could be too much, causing detonation.
Doc99SS is offline
Old 03-08-2005, 08:13 PM
mako350Z28's Avatar
When you adjust the timing you're maximizing the timing curve, or when the spark plugs fire. Remember, the combustion process takes the same time at idle as it does at 5000 RPMs, this why timing advances are necessary. As the RPM's increase, the plugs have to fire sooner so the combustion process takes place when the piston is at the top of the cylinder.
The factory is a bit on the conservative side when it comes to timing(among other things), so if the timing is adjusted to the optimum firing point: more power, better response, and in turn better fuel economy - if you can keep your foot out of it.
Old 03-08-2005, 09:01 PM
85_305's Avatar
Wait.. your talking about cam-timing right? Or are you reffering to dist. timing? Will advancing your cam timing actually be NOTICABLE while driving?
85_305 is offline
Quick Reply: suggestions on how to make easy bolt on horse power for cheap
