Striped stud on back wheel
E-Z just knock the old one out an put the new one in put afew flat washers on the stud ,then an old lugnut backwards so the flat side is against the washers and tighten to pull the stud in all the way,remove nut& washers,then install wheel and torque to proper specifications,recheck after afew (50-60)miles. You might have to spin the axle to clear componets but you should be able to get it out without pulling the axle.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Jul 4, 2005 05:00 PM
A BIG hammer...good luck let us know if it works out.
