strange hose unplugged
Old Jul 7, 2003 | 03:33 PM
kevin 2.8's Avatar
behind my driver side headlights theres a canister, next to that i think is the cruise control, coming from the cruise control theres a hose that splits like a T then dissapears into a harness...
the bottom of the T is not connected to anything, its a good 15 - 20 inches long and not a very thick hose.
what is it and where does it go?
2.8 v6 mpfi cruise a/c power everything
Old Jul 7, 2003 | 10:08 PM
kevin 2.8's Avatar
Unhappy
come on.....
Old Jul 8, 2003 | 09:55 PM
stanghunter211's Avatar
Look around the throttle body for an open fitting, like a slip on type deal, where the vacuum line, at least thats what it sounds like would go. Thats a charcoal canister and its used for emissions purposes..... I have never owned a 2.8 so I am going off of what I know from my iroc and Z. Hope it all gets worked out, im sure its right under your nose.
Will
Old Sep 16, 2003 | 03:49 PM
Buck89RS's Avatar
I think i know what that is. Its the hose that should go down in the fender to a plastic piece that is just a vent hose of some type for the cruise, but it does connect to a vent hole underneath or around the front left tire area, hope this helps
-William
Old Sep 16, 2003 | 07:04 PM
kevin 2.8's Avatar
wow i forgot about this post but i havent fixed the probelm. i checked on some other third gens bu reaching down into the fender and it does connect to a plastic peice that i cant see from under or looking on top... is it important? my cruise control wont work unless i mash the buttons about 10 times
Old Sep 17, 2003 | 07:22 AM
Buck89RS's Avatar
I would say that if it is suppose to be connected, then connect it, that is my advice.
-William
Old Sep 17, 2003 | 08:18 AM
Jim85IROC's Avatar
It sounds like the vacuum line going to the vacuum reservoir. If you can see where to plug it back in, do it.
Old Sep 17, 2003 | 09:46 AM
kevin 2.8's Avatar
but thats the problem, i cant see where it is supposed to go
Nayr
Mar 3, 2023 08:34 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
