Steering Issues
Old May 5, 2004 | 04:35 PM
  #16
aklim's Avatar
Originally posted by KnightRider350
No, I haven't yet. Do you know where there's one in madison, and how much it would cost? I'm going to shoot myself if the frame's bent. All those mods....
I forgot. It has been a few years but Grey Bahl on Fair Oaks will do that.
Old May 5, 2004 | 06:53 PM
  #17
KnightRider350's Avatar
Well its not just going right doug. It goes in a perfectly straight line until I turn it. Its memory steering. If I turn right it'll pull right until I turn left---then it'll go straight. So its not like its perpetually going right. It only goes right until I adjust it...that's why it sounded like a steering box/front suspension thing to me. now that there IS nothing in the front suspension that's NOT brand spankin' new...I'm running out of options.
Old May 5, 2004 | 08:07 PM
  #18
aklim's Avatar
Give Jim Piper a call. His shop is on the beltline area. Accurate Alignment. He might have some ideas
Old May 6, 2004 | 11:17 AM
  #19
Pneumatic_Tire's Avatar
Knight Rider, caster is what makes your steering wheel pull itself straight again after being turned. You say you had an alignment done, so I doubt it's out. Did you check your tire pressures? Doubt that is it too from what you are describing, but I'm just throughing ideas out. Good luck!
Old May 6, 2004 | 01:56 PM
  #20
Thanks for the info pneumatic, but yeah I had the tires rotated, filled up the pressure in all four tires and had that allignment done. I get free allignments for the next 6 monthes or whatever, so after the next batch of dicking around I do, I'll go in and have them redo it just to make sure.
*sigh* I just wish this part of the project was over!
Old May 10, 2004 | 07:01 AM
  #21
Joe 97RA's Avatar
Sounds simple, but are you sure the rear wheels aren't steering the car? If something were loose and the thrust angle of the rear tires doesn't stay locked, you will get exactly what you are experiencing. Are you getting any throttle induced steer? if so, that may point to control arms. If not, look to the panhard rod. A slight shift can affect thrust angle.
Old May 10, 2004 | 09:10 AM
  #22
Never thought of that. Thanks.
Good excuse to get LCA's and a new panhard.
http://www.thirdgenresource.com/inc/pdetail?v=1&pid=855
Does that include everything? I'd get the LCA relocation brackets as well. Are trailing arms different then control arms? Sorry for such a noobish question, but I see LCA relocation brackets for sale on thirdgenresource, and I see trailing arms for sale---but no actual control arms for sale.
Victor Lamb
Aug 26, 2017 02:52 PM
nikko
Apr 28, 2015 10:05 AM
Airplanedoc
Feb 1, 2015 07:14 PM
ro2207
Dec 4, 2014 06:18 PM
