StealthRam upper rad hose?
Old Nov 27, 2004 | 08:25 PM
Bristol's Avatar
Does anyone know which hose will work? If I can use "1" hose or if I have to use "2" pieces clamped together????
Thanks.
Kris
Old Nov 27, 2004 | 09:05 PM
aklim's Avatar
Re: StealthRam upper rad hose?
I used an OEM hose and another hose that fit. The OEM hose is attached to the radiator and will move towards the back of the car, then towards the right and back towards the back. At this third joint I cut it off. Then I go out and get a hose that will fit this waterneck. This will have to have one end that will fit the hose and the other which is larger that will fit the water neck. Then I cut them and splice them with a hose joiner,
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
jackpawt883
Sep 10, 2015 08:53 PM
