Starting problem?
Old Mar 11, 2007 | 09:17 PM
Tom85T/A's Avatar
Starting problem?
Last Sunday went to start up my cars all started except the 85,all it did was click a few times and then just a low whining sound,checked the battery and alt all were good,was very cold that week,due to work did not have much time to check it out better,tried a few times during the week same thing click and whine,so today being warm about 55 thought I pull the starter,tried it one more time and it started right up runs fine now any ideas before I go any further?
Old Mar 12, 2007 | 12:33 AM
quickchicken's Avatar
make sure your connections are clean to start with. you say it was cold, your batt may not have enough cold cranking amps or was on a low charge making the equivelant of not enough cold cranking amps.
Old Mar 12, 2007 | 08:35 PM
respectirocz's Avatar
how do you know your battery is good?, what did you use to test it?
it may be too weak to start in the cold but fine when warmer
Old Mar 13, 2007 | 07:23 PM
Tom85T/A's Avatar
Know battery is good had it tested also tried a brand new battery from one my others cars,has plenty of cranking amps
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
