Starters
Old Nov 24, 2003 | 01:25 PM
Garage Inc.'s Avatar
Starters
I'm thinking about replacing the starter in the Z28 but I need some advanced opinions on brands and cost (I've seen them new for 150-300 bucks )
Is Accel good?
Old Nov 24, 2003 | 02:40 PM
Blown350ZZ4's Avatar
I don't know enough to recomend a brand, but I do know this. Make sure you remember what terminals your wires go to. Write down what wire goes where or else you risk no juice running through your car.
Nick
Old Nov 24, 2003 | 02:47 PM
kandied91z's Avatar
when it comes to these sorts of parts i like gm personally. its definately more expensive but worth it in the end. i have an lt1 ministarter on my car and works great. i've learned over the many years trying to use discounted pieces that have been remaned only to find out they are in bad shape and don't last long.
another good idea is to find a small repair shop that deals with these parts and make good with the people there. i wouldn't pay the high price to have names like accel or others on the parts as those are mostly outsourced anyhow.
Old Nov 25, 2003 | 06:03 AM
Brit Iroc's Avatar
I agree with kandied. Mine packed up and I got a GM perf. part hi-torque mini-starter. Very pleased with it.
Old Nov 25, 2003 | 09:01 AM
ktm520's Avatar
summit sells a gear reduction mini starter with their name on it for 150$. i've had it for three years now without a single problem. it cranks my hi-compression small block over without a problem.
Old Nov 25, 2003 | 06:19 PM
TheGreatJ's Avatar
I went with a GMPP gear reduction starter as well. It's been over 2 years and the only trouble I've had was a mild heat soak issue last summer. Too close to the headers and no heat shield means an unhappy starter no matter who you buy it from. It still works though, and now that the weather has cooled a bit she has no trouble. I'll get a heat shield in there before spring and that should be that.
Old Nov 26, 2003 | 02:08 PM
Thanks for the replies guys!
Going with a mini starter but now I have another problem. I replaced the battery today after it stopped cranking. I got a kickass deal on a new battery ($25) but now it just cranks and doesn't start! Anybody know anything about....
DISTRIBUTORS!
Old Nov 26, 2003 | 04:41 PM
Black6SpdTA's Avatar
Ut oh...Have you checked for spark to all 8 cylinders? How long was the motor "not starting?"
Old Nov 26, 2003 | 06:04 PM
TheGreatJ's Avatar
If you get no spark, check for power at the coil. You may have blown a fuse/fusible link. Ignition module is also a likely culprit for a no-spark condition in these cars.
Old Nov 27, 2003 | 03:51 PM
kandied91z's Avatar
also check the cap, i had a rotor explode on me which wasn't any fun....
Old Nov 28, 2003 | 12:19 AM
yup, got a screwdriver and no spark!
I'm having a buddy of mine look at it tomorrow, he's a well known mechanic around here...
thanks for the replies guys
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
realistyc
Jul 28, 2015 07:32 PM
