starter wont shut off... ?
Old Aug 16, 2003 | 05:36 PM
Polo-94Z28's Avatar
Question starter wont shut off... ?
Tried to start the car today.... turn the key to start... and the starter wont shut off! I have to disconnect the battery to kill it. Didnt do this before... I dont think its ignition key related... even if I pull the key all the way back to off and out its still crankin away. Ugh I hope i dont have to pull the starter out and check it out. Anyone have this prob before?
Laterz
Old Aug 16, 2003 | 11:09 PM
aklim's Avatar
Sounds like you need to check and see if the starter is clearenced right. When mine was way off because one end was cocked by the oil pan (long story), there was one time it did the same thing as yours. If the starter gear cannot disengage, it will keep current flowing somehow and keep it turning. Maybe it is very hot out there and somehow the gear got stuck in the out position?
Old Aug 17, 2003 | 01:17 AM
Polo-94Z28's Avatar
Yeah, I took the starter off and checked it... passed fine. I even went so far as to take the solenoid apart and checked it all again. Was fine and dandy. Placed it in the car and just hooked up the ign key input... the gear extended and retracted just fine. Soon as I placed battery power with the key source... bam. Wont stop turning over. Grrr... hmmm.
Old Aug 17, 2003 | 10:23 AM
aklim's Avatar
You sure it is shimmed correctly?
Old Aug 17, 2003 | 10:46 AM
TheGreatJ's Avatar
It sounds like the starter is too close to the flywheel. Try adding a shim or maybe 2 and if that doesn't work the solenoid is just jamming and probably needs replaced.
Old Aug 17, 2003 | 11:31 AM
Polo-94Z28's Avatar
I went under the car and took a look and the meshing between the starter pinion and the flex plate... soon as I loosend the starter motor it retracted back in... w00t! lol Yup yup That was the problemo. Stuck a shim in there and its all good. Thanks much.!
Laterz
-Zach
Formula Steve
Sep 19, 2023 08:31 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
KYWes
Sep 26, 2015 08:49 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
