Starter Issues / Brake Issues
Old Jun 14, 2005 | 12:08 PM
  #16
respectirocz's Avatar
Re: Starter Issues / Brake Issues
do u have a heat sheild on your starter slenoid? sometimes if u dont have a heat sheild the solenoid absorbs all the heat from the exhaust manifold and doesnt work, then when it cools down it works fine, the usual solution is to get a starter heat sheild
Old Jun 20, 2005 | 05:37 PM
  #17
camaroken's Avatar
crews is right about the battery voltage, but i would check the alt too cuz 13.6 seems a little low usually it is 14.5 to 15 volts running. alt might be on its way out. but you need a fully charged and good battery to be acurate on the alt voltage. I really like to use amperage test myself on alternators to get a true output from it though.
dluna333
15
Mar 13, 2015 12:30 PM
rwferguson43026
Feb 6, 2015 10:06 AM
ddr698
Jan 9, 2015 10:05 AM
Jan 5, 2015 07:14 PM
Jeff1904
Jan 3, 2015 12:00 AM
