Starter
Old Jul 19, 2005 | 10:12 PM
LoudmouthSS's Avatar
Starter
Can someone post a pic of their starter with all the wires connected.
Or explain where all the wires go on it...thanks
Old Jul 19, 2005 | 10:14 PM
85_305's Avatar
Re: Starter
Have fun man, I had the same EXACT problem at one time
Unfortunatly, it pissed me off so bad that I said "F*ck it" and had my friend do it.
Old Jul 19, 2005 | 10:58 PM
Re: Starter
god damn you lol
....i looked in the haynes book....tells you absolutely jack ****
Old Jul 19, 2005 | 11:09 PM
LesPaulGoth's Avatar
Re: Starter
If you posted this about a week ago, I could tell you, but I remember a little. I wired mine the same way the stock was wired. If I'm correct...in the small terminal there is a yellow wire. All the rest (three wires) should go on the large terminal. On the large terminal there was a single red wire, a double wire with one connector (i believe it was red and black colored, and a thick black wire. I'm pretty sure thats what it was.
Old Jul 20, 2005 | 12:24 AM
Re: Starter
ok but which small terminal...mine is set up like this.... small o largeO smallo
there's two small terminals..
Old Jul 20, 2005 | 05:02 AM
fade2blk500's Avatar
Re: Starter
I want to say it's the bottom terminal if I recall correctly.
Old Jul 20, 2005 | 01:30 PM
angel71rs's Avatar
Re: Starter
The purple wire comes off the ignition switch and goes to the terminal (S terminal = switch) closest to the block. That's how it's been on Chevys for decades.
Formula Steve
Sep 19, 2023 08:31 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
4586
Aug 18, 2015 07:08 AM
realistyc
Jul 28, 2015 07:32 PM
