springing leaks everywhere..why?
Old Jan 24, 2008 | 12:57 PM
Wishmaster's Avatar
I cant seem to stop oil leaks. no matter what I do another leak comes up somewhere else.
Do I have to much crankcase pressure causing the seals to leak? I canr really tell where some fo the leaks come from....1 is the oil filter, the other is the mating between the pan and the gasket on the rear right under the rea main and something is dripping oil all over my starter, imm thinking its from between the head and block. ITs seem like when I seal one and other pops up somewher else like I have to much crankcase pressure so its gonna find a way out somewhere.
Im running the stock PVC setup but thinking about doing away with all that and just putting filter breathers on both valve covers and pluging the holes on the throttle body and the plenum.
Im running a MAF set...have way high oil pressure due to the HV pump and gapped my rings for nitrous use according to KB specs.
Old Jan 24, 2008 | 10:40 PM
1989TransAm's Avatar
If this is a new motor it is posible to get some blowby. However the rings should seat quickly enough so the blowby stops. We just started up a new motor and it had some blowby. After maybe 5 miles it stopped.
calaban
May 18, 2020 06:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
ChrisFrez
Mar 29, 2015 09:43 PM
Red_94Formula
Jan 22, 2015 12:17 AM
CR97WS6
Sep 3, 2002 02:31 PM
