Spohn torque arm problem
Old Aug 12, 2002 | 11:15 AM
1986lt1boy's Avatar
Post Spohn torque arm problem
Hey guys i just bought a spohn torque arm and put it in my car (1986 trans am 4l60e tranny and ford 9 inch rear). When ever the car goes over 3000 rpm there is a crazy vibration. I know its not the drive shaft because i bought a new one that was completely balanced. Has anyone done this? or heard of anything like it.
Tom 1986 trans am
Old Aug 12, 2002 | 11:42 AM
mr diabolical's Avatar
Post
everything is tightened good on the torque arm like all the lock down and adjuster nuts? make sure the front torque arm to crossmember bolt is real tight. what all did you change before the vibe came on?
[This message has been edited by mr diabolical (edited August 12, 2002).]
Old Aug 12, 2002 | 12:42 PM
1986lt1boy's Avatar
Post
The only thing i replaced was the torque arm. Thats when the vibration started. everything is tight. i think it might be the solid metal bushing that holds the arm to the front tranny crossmember.
TOm
Old Aug 12, 2002 | 04:21 PM
AutoRoc's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by 1986lt1boy:
TOm
</font>
Very possible. That's why they call it a race version The steet version has poly bushings if i'm remembering right. Goodluck
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Old Aug 13, 2002 | 06:20 AM
funina91ss's Avatar
Post
did you set the pinon angle correctly if not it will cause a bind in the ujionts and cause a nasty vibration I have the same problem with my sphon tq arm but I think mine is the drive shaft stock steal it was fine untill I bent my stock tq arm then I have had a vibration every since that happend I am orderind a drive shaft this week and hopefully it will all go away.
91 Camaro SS
305 tbi edelbrock intake &strut brace crane compucam march underdrive pulleys ads superchip k&n open air cleaner mac headers & subframe con. 3"flowmaster ascd ss hood and gm ss rims 6 speed star spec stage3 carbon fiber clutch Sphon suspension eibach sport line springs bilsten shocks and struts,mosser 12 bolt 4.11, 400+hp lt1 in the build up waiting to get the heads back. carbua targa rs seats ,pics http://www.ofoto.com/Slideshow2.jsp?...id=89850812303
Old Aug 13, 2002 | 08:58 PM
millican's Avatar
Post
........I know its not the drive shaft because i bought a new one that was completely balanced. .......Thanks
Tom 1986 trans am
</font>
No guarentee even a new driveshaft balanced can be wrong. I had a buddy with one (new) that still vibrated like crazy. He swapped my old '86 stock shaft in and no vibration. he got his money back for the new shaft.
I think they tried to "shaft' him.
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Transmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
LT1 Intake Website
Moderator at SE ThirdGen
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
