Speedometer doesn't work
Old Feb 24, 2006 | 10:29 AM
Uc360's Avatar
i have a 91 z28 305tpi HO auto trans, and my speedometer doesn not work, anyone have any suggestion on what i should try to figure out why??
Old Feb 24, 2006 | 10:37 AM
Dave89IROC's Avatar
Re: Speedometer doesn't work
is your check engine light on?
Old Feb 24, 2006 | 12:49 PM
nathan96's Avatar
The VSS go bad from time to time and are easy to replace. Although I am interested in why Dave is asking about the CEL.
Old Feb 24, 2006 | 03:34 PM
thirdgenrallysport's Avatar
just check your connection so the speedo sensor in the back drivers side of the tranny. is your electronic or mechanical? 91 i would think electric. might just be a bad connection.
Old Feb 24, 2006 | 03:53 PM
Dave89IROC's Avatar
if the CEL is on(or a code for VSS set), it almost garranties the sensor or wiring between it and the ECM is bad, if there is no code, there is a problem between the ECM and the speedo
eazyZ
Mar 1, 2015 07:12 AM
sdn1997rs
Dec 30, 2014 08:30 AM
Jul 4, 2005 05:00 PM
Evilfrog
Aug 7, 2002 11:36 PM
Snake Slayer
Jul 26, 2002 06:14 AM
