Spark plug gap Q
Old Feb 9, 2004 | 03:56 PM
StealthElephant's Avatar
Spark plug gap Q
I've got almost 11:1 compression and I'm not sure exactly where to gap my plugs. I've been keeping them around .035 but should I go tighter with higher compression....like .03 or .025?
I'm running the R42LTS Delco plug...not sure if I should go up a heat range or 2.
Old Feb 9, 2004 | 04:43 PM
trackbird's Avatar
I higher compression motor will typically need a cooler plug (something on the cooler end of the scale) to avoid detonation.
As for gap, you can experiment by moving your gap .002 each way and looking for better performance/gas milage. When it drops off, back up a setting. Just go larger or smaller, .002 and run it. Get your baseline mileage and et and go .002 more, etc.
Old Feb 9, 2004 | 10:32 PM
aklim's Avatar
I am using NGK ones that are the stock replacement but one heat range cooler. Also I have an Accel coil and have cranked it up to 45 without any problems. YMMV. I am running 10.8:1 compression
Old Feb 10, 2004 | 01:42 AM
Sitting Bull's Avatar
For a more complete burn, try to run at least .035. If you have an aftermarket coil you should be able to spark a .045 gap without drama.
Old Feb 10, 2004 | 02:15 AM
aklim's Avatar
I do wonder tho, what about those multi-strike systems like MSD and Accel 300+, etc?
Old Feb 10, 2004 | 10:05 PM
Hmmm...I figured that .035 would be more then enough, I have a standard accel coil and breakerless distrib...someone told me I should run like .025 gap with my compression.
Old Feb 11, 2004 | 12:37 AM
aklim's Avatar
If there was hesitation especially at high RPMs, I might suspect your spark being blown out and try reducing the gap.
Old Feb 17, 2004 | 10:42 PM
pwrhngryj's Avatar
I run the gap at .035 with about the same and a 100 shot of NOS on stock plugs.
jayblev95
Jun 7, 2015 04:04 PM
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
