Spacers for SS/ZR1 Rims on a 3rd gen?
Old Jul 17, 2006 | 06:55 PM
staleyracing's Avatar
I was wondering what size spacers are needed for a set of SS/ZR1 rims on a 3rd gen. the backspace is 56mm. If anyone knows where to find the spacers at please lemme know thanks
Old Jul 17, 2006 | 10:39 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Re: Spacers for SS/ZR1 Rims on a 3rd gen?
http://www.skulte.com/
Old Jul 18, 2006 | 02:52 AM
streetheatz28's Avatar
I bought mine off ebay, 2" all the way around gives it a mean appearance. They cost me 148.00 with tax and shipping included and they arrived at my house in 3 days.
- Charlie.
Old Jul 19, 2006 | 11:37 PM
StevenK's Avatar
Originally Posted by Kevin91Z
I run the Skulke "Adapters" for my ZR1s. Notice I said Adapters, not spacers, they are two entirely different things.
Spacer = peice of metal, requires that you change your wheel studs to longer (and stronger if your smart) parts to allow you to still be able to put on the lug nuts.
Adapters = peice of metal with 5 holes, and 5 studs. You put the adapter on using your stock studs, and bolt em down, then you use the 5 studs on the adapter to mount the wheel.
You need 2 inch in the front, and nothing in the back if your running a 4th gen rear. If your running a thirdgen rear, I think you need 2 inch in the back as well. I'm running a 4th gen rear, so I can't confirm the 2 inch for the back.
Old Jul 20, 2006 | 02:43 PM
Zepher's Avatar
I had the Vettebrakes ones and I prefer the skulte ones I have now.
the vettebrakes ones used deep shank lugs and the skulte ones use the stock acorn style which helps to center the adaptor on the hub.
I am running 2" on the front with my ZR1's and I own both offsets, the shallow offset ZR1's required me to clearance the tie rod by 1/8th of an inch, the other offset works fine with no modification.
Old Jul 23, 2006 | 12:11 PM
shady54's Avatar
If you want Zr1s for your 3rd gen then look at slponline.com they have zr1s especially made for the 3rd gen i have some and bought them for 654 shipped. which i thought were pretty good.
Old Jul 23, 2006 | 12:15 PM
Rottluver's Avatar
That is true but unfortunately if memory serves, they only come in 16x8.....lotta folks want that 17" wheel/tire combo so going with SLP won't cut it. If you don't mind the 16" size, I love the look of those SLP "ZR1's" and would love to see a picture of them in the "hyper-black" color they sport as well.
Old Jul 23, 2006 | 05:11 PM
Zepher's Avatar
Actually, they are 17" but only 8" wide. They have a nice look since they have a little dish to them, but 8" isn't wide enough for me.
Old Jul 24, 2006 | 11:26 AM
Rottluver's Avatar
<slaps self> Sorry, my bad........you are correct sir and I apologize for the misprint. I see 8" wide and immediately my brain thinks 16"
Must be the thought of having to buy a tire that is 245/50-17 that freaks me out. Especially since I have been running 275/40-17 and 315/35-17 for the last few years on my car.
Old Jul 28, 2006 | 11:39 PM
1987IROC350's Avatar
Check out these ZR1 wheels. Direct fit without spacers for 3RD gen. They are same as SLPONLINE.COM http://www.afterthoughtsauto.com/whac.html
BLK1997Z28
May 2, 2015 01:26 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
19redta96
Jul 23, 2002 12:25 PM
stars1010
Jul 15, 2002 03:51 AM
