something loose/broken in the front end???
i hit an uneven point in the road fairly hard cause i didnt see it. and i think something might have broken off. shortly after i hit it, my front right tire felt like it ran over something pretty violently but i couldn't see anything in the road. now there is a loud noise coming from the front end and i can't tell what it is. everything seems firm and nothing loose but i cant tell if something is missing or broken. it also makes a clunking noise when it shifts from first ot second. it feels like its coming from the front middle of the car, but its hard to tell. any ideas?!?!?!
[This message has been edited by pcolaIROC (edited September 02, 2002).]
clunking sound from 1 to 2? Have you checked your Tranny mount? Its a long shot but an idea.
Have a friend get in the car and put it in gear with their foot FIRMLY on the brake. Have them apply pressure to the gas and see if the tranny starts to pick up from the crossmember. It should move only a little bit, perhaps .5 to 1 inch, if it is still ok. It will move a few inches if it is broken. You'll know... you'll see the mount is ripped.
Good luck bro.
-Brad C?
355ci '89 Iroc-Z Red, T-tops, power everything, A4,New 10 bolt w/ 3.73's
Trans-Go shift kit Corvette Servo,Accel 8.8mm wires,Flowmaster 80 series ,K&N's, !MAF Screens, Hollowed out airboxes,homemade Subframes. Kieth Black pistons 10.3:1, Comp Cams 270H (.495/.502 218*/224* 110*LSA) & valve springs, SLP 1 3/4" headers, TCI 2400 stall, Dual Roller timing chain, 2 3/4" I-pipe.
Full street trim best run:14.799/mph:93/60': 2.02 (last year) New Times to come.
New times: 13.732 @ 99.30 on a 1.878 60'
Pics of the Iroc
Good luck bro.
-Brad C?
Pics of the Iroc
PublicEnemy1
Apr 7, 2015 12:21 PM
