So, I just bought a 1991 Camaro. . .
Old May 10, 2007 | 11:03 PM
Demosthenes's Avatar
RS, with a V6, for $500. . . it just hasn't been started for about 2 years. . .what should I do before trying to fire it up?
Old May 11, 2007 | 08:11 AM
1987IROC350's Avatar
Pray, main thing is I would change the oil. And make sure all other fluids are full.
Old May 11, 2007 | 10:49 AM
teke184's Avatar
maybe squirt some oil down into the cylinders...just to lube the rings up a bit on the dry fire.
i'd maybe try some fresh gas. pull the fuel filter and turn the ignition on, let the gas pump out. then refill it.
Old May 11, 2007 | 01:32 PM
Originally Posted by Gunny Highway
Pull the motor and throw it into a lake.
Old May 11, 2007 | 04:38 PM
nikkev's Avatar
Definately ditch the old gas.
Old May 11, 2007 | 04:58 PM
JeremyNYR's Avatar
dude, that's not very nice.... you should dispose of it properly! hehe. Just kidding, there's nothing wrong with having a V6. Maybe you'll want to go to a V8 someday, maybe not. can't beat the price though if the body is in good shape and you get get it running.
Old May 11, 2007 | 05:03 PM
mdacton's Avatar
drain the oil and when you fill it crank it with the coil wire off til you get oil press.
Good luck with it
Old May 11, 2007 | 05:40 PM
Duke's Avatar
Good luck with it
Agreed, and a new fuel filter wouldn't hurt.
Old May 15, 2007 | 04:41 PM
Rage's Avatar
I would definately change out all of the fluids and check to make sure that the fuel pump acutally pumped gas through the lines. If it doesn't, the lines may be clogged. Good luck.
Old May 16, 2007 | 04:52 AM
Purple 92 SS's Avatar
liek the rest say, change oil, lube cylinders with oil, then pray
Old May 16, 2007 | 09:31 AM
Mr. Wolf's Avatar
change Vacum lines or just check them for dry rot
jasonduaine
Apr 1, 2015 08:09 PM
grabbem88
Mar 25, 2015 12:09 PM
95chwagon
Feb 28, 2015 12:02 PM
bernie1951
Dec 10, 2014 10:03 AM
99TransAmWS6
Jul 26, 2002 03:18 PM
