Yep, that's the right part number. I don't know why they label it as a water pump pulley, but they do. It's the same way with the AC delete pulley, they list it as something else.
And, yes, it just bolts right into the stock location where the smog pump was.
solid.Thanks man.
Hi. I've been thinking of doing this to my 90 camaro.
I have a question about this....
If I remove the Smog Pump and the lines from my manifold, will this effect the ECM/Computer? Will I need to install a custom chip?
Thanx!
Thanx!
I have March underdrive pulleys (alternator, water pump, and crank) and the a/c delete pulley and I want to get rid of the air pump by just removing it all together. What size belt will I need? I'm guessing the underdrive pulleys won't change the length of belt I need so will the 968K6 size belt work?
I think you can retain your original belt size, with the under drive pulleys installed. Let me look around for a min...
Got it:
Check this message
Also, if you have not read their tech article on how to remove the smog pump
Got it:
Check this message
