Smog pump delete?
Old Feb 11, 2005 | 06:11 PM
  #16
Ben91RS's Avatar
Re: Smog pump delete?
Yep, that's the right part number. I don't know why they label it as a water pump pulley, but they do. It's the same way with the AC delete pulley, they list it as something else.
And, yes, it just bolts right into the stock location where the smog pump was.
Old Feb 11, 2005 | 11:09 PM
  #17
stealthblack's Avatar
solid.Thanks man.
Old Feb 12, 2005 | 01:15 PM
  #18
ledhead96's Avatar
Cool Re: Smog pump delete?
Hi. I've been thinking of doing this to my 90 camaro.
I have a question about this....
If I remove the Smog Pump and the lines from my manifold, will this effect the ECM/Computer? Will I need to install a custom chip?
Thanx!
Old Feb 12, 2005 | 01:23 PM
  #19
jconrad's Avatar
ledhead, I've been runnin w/o AIR and the heater valve since March 2004. Never set a code yet...hope this helps
Old Mar 11, 2005 | 01:37 PM
  #20
Zrated383's Avatar
I have March underdrive pulleys (alternator, water pump, and crank) and the a/c delete pulley and I want to get rid of the air pump by just removing it all together. What size belt will I need? I'm guessing the underdrive pulleys won't change the length of belt I need so will the 968K6 size belt work?
Old Mar 12, 2005 | 03:16 AM
  #21
jconrad's Avatar
I think you can retain your original belt size, with the under drive pulleys installed. Let me look around for a min...
Got it:
Check this message
Also, if you have not read their tech article on how to remove the smog pump
HarleyZ28
Oct 5, 2015 06:23 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
alphaauto
Jan 23, 2015 07:42 AM
Timberwolf
Aug 9, 2002 11:24 AM
Dark Angel
Aug 8, 2002 08:43 AM
