smog pump bull
Old Jun 9, 2004 | 12:13 AM
jmac86iroc's Avatar
smog pump bull
I have an 86 iroc with tpi and i don't know if i can run the fuel injection without a smog pump and the computer still function properly.
Old Jun 9, 2004 | 12:28 AM
Pneumatic_Tire's Avatar
I'm pretty sure you can ditch the smog crap, I know it was done to my 85 Z by the previous owner. It has a computer controlled carb, and it does not throw any codes. I don't see why it would be a problem with the TPI, but I could be wrong. Wait for someone with a TPI motor to chime in before you do it.
Old Jun 9, 2004 | 12:53 AM
Stephen 87 IROC's Avatar
Other than emission testing requirements the only thing the "smog pump" A.I.R pump is used for is to inject air into a cold exhaust to lower the emissions. Once an engine has reached operating temperatures, the added air into the exhaust isn't required. Without the pump, the computer may keep the engine in an open loop longer. Using a heated O2 sensor will help.
If you have to do emission testing, make sure the car is hot before it's tested. If they do a visual check for the pump then you'll need to have it on the engine.
Old Jun 9, 2004 | 12:47 PM
virtualdemo's Avatar
Both the cars in my Sig dont have the A.I.R on em. No codes for the past two years on the Bird, I just got the IROC and no codes for the past two months... It wont bother anything, just make sure to pull back the pump wiring so that it wont get burned or pulled in by the belts. AND yes I know by experience....lol
Lates,
Demo
Old Jun 9, 2004 | 03:55 PM
aklim's Avatar
I don't think so, at least on mine. When the engine just starts up and the cat is cold, it diverts air into the exhaust manifold to meet the hot exhaust and give it time to mix so as to get lower emmissions. Once it is hot, air is piped into the cat directly. In any case, since you don't have aftercat sensors, the ECM will not know the difference. If you are driving it int he winter, heated O2 sensors might help but otherwise, don't waste your money. I have disconnected my heater elemets and not noticed that my car was dropping out of closed loop especially in the summer.
Old Jun 11, 2004 | 12:37 AM
jmac86iroc's Avatar
I was worried if it would code anything at all or not. I was just wondering if i had to do anything with this one little black thing that hooks up to the pumpthat has 2 plugs that hook into it and i didn't know if that could be thrown away or just take it an throw it on the side.
Old Jun 11, 2004 | 12:42 AM
I assume that black thing you are talking about is the diverter valve. It goes along with the A.I.R. crap. You can get rid of it too.
Old Jun 11, 2004 | 12:53 AM
jmac86iroc's Avatar
that is it i just didn't really know its name. do i have to do anything with those 2 plugs or can i just put them on the side.
Old Jun 11, 2004 | 02:44 AM
Just put em to the side away from the exhaust somewhere. You'll be good to go.
Old Jun 11, 2004 | 09:44 AM
aklim's Avatar
Zip tie them away in case you need them. Also cover the ends with some electrical tape to be safe.
Old Jun 11, 2004 | 09:53 AM
jmac86iroc's Avatar
yea that was what i was going to do. probably fasin them down on the fender well or something
Old Jun 11, 2004 | 01:25 PM
aklim's Avatar
Ooooh, before you do seal up the plug units, a shot of dielectric grease won't hurt.
Old Jun 13, 2004 | 11:30 AM
ViperXx's Avatar
hmm, I have a 89 camaro with a 5.7L TBI and I was going to remove my smog pump but I couldn't find a belt to fit without the smog pump, does anyone have a part id# or something that would fit?
Old Jun 13, 2004 | 01:02 PM
***Use the Dayco 968K6 belt. It is basically a 96.8" 6 rib belt.***
Got that off of Thirgen.org. I am thinking of getting a shorter belt though. It still looks sorta long on my Bird. Good thing the IROC had the V-belt...lol I also heard of a delete pulley, dont know if its the A/C delete pulley or not, just something else to check on...
Lates,
Demo
Old Jun 13, 2004 | 01:22 PM
Dave89IROC's Avatar
http://www.thirdgen.org/newdesign/tech/serpentine.shtml
