smelling problem
Old Jan 16, 2003 | 07:44 PM
willis2z's Avatar
Unhappy smelling problem
I've got a 1989 IROC with a 305 tpi 5Speed dual cats(2 years old) car has 17,700 orig miles.When i get on it hard there is a bad smell like something rotten.Under normal driving cond. it's fine.Can any one tell me what's up.
Old Jan 16, 2003 | 08:35 PM
87DJP2001's Avatar
The smell of rotten eggs is from the Cats and is normal.
Old Jan 16, 2003 | 08:39 PM
willis2z's Avatar
Thanks for the reply.Just wondering because i never had it happen on my 95 z. When it had a cat.
Old Jan 16, 2003 | 11:20 PM
I EAT T/A's Avatar
I don't recall ever smelling rotten eggs while behind an f-body before. I've only smelled that crap while behind certain car makes.
Old Jan 17, 2003 | 03:07 AM
IROCThe5.7L's Avatar
I always though that when your cats start smelling like that, it means they are going bad.
Old Jan 17, 2003 | 04:29 AM
Lounge Lizard 6's Avatar
Actually it means you are running rich. If you run rich that will kill the cats.
Old Jan 17, 2003 | 04:34 AM
Chris Ja's Avatar
Eternal Member
If it has a bitter sweet smell it is coolant. At the age of your car you might need a heater core. Under load the cooling system builds more pressure and it leaks alittle more. Keep a eye on your coolant level and if you have to add any then I would check that. Also if it breaks loose you will have the right front carpet soaked. You windshield will also get a grease film.
If it is the converters under load the car will bog once they get restricked. The car will start loosing power and the more gas you give it the slower it will go.
You did not say what how it smelled so I thought I would tell you about the heater core. It is something you should start watching now. Hopes this helps.
Old Jan 17, 2003 | 02:49 PM
willis2z's Avatar
The smell is like rotton eggs.The cats was replaced with oem setup,which have 10,000 miles on them.The engine dosn't seem to be running rich unless at wot.As soon as I get out of it it goes back to normal.I'll try reajusting the tps.THANKS AGAIN
Naanz
V6 Tech
Feb 14, 2016 11:11 AM
Lt4Z2897
Mar 26, 2015 03:02 PM
lt1matt
Mar 21, 2015 07:35 PM
MattFick
Feb 15, 2015 10:16 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
