small blocks interchangeable on the outside
Old Sep 16, 2003 | 06:38 PM
CamaroZ28Coupe's Avatar
i diddnt know what to tittle this post but anyway are the engine mounts the same with all the GM engines like the pontiac 400's and the oldmobile 350 and of course the chevy 350? basically are all small blocks interchangeable on the outside?
Old Sep 16, 2003 | 06:54 PM
TheGreatJ's Avatar
The Chevrolet smallblocks (283,305,327,350,383,400) are pretty thoroughly interchangable. They do NOT interchange with the BOP (Buick, Olds, Pontiac) line of engines. They also don't interchange with Caddillac specific (i.e. 4.9l Northstar) engines. The BOP engines should interchange with each other...Caddy motors are on their own which is one reason parts are so expensive.
Old Sep 16, 2003 | 07:04 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
J's right although he left a few sbc out, and the 383 sint an OEM block But other than that hes right, just incase you wanted conformation.
Old Sep 17, 2003 | 01:21 AM
m0nk's Avatar
Thats right, my brothers 267 gets forgotten many times
Old Sep 17, 2003 | 01:42 AM
DarthIROC's Avatar
Few others too, 302, 265, 307
Old Sep 17, 2003 | 09:03 AM
82355's Avatar
262, 265, 267, 283, 302, 305, 307, 327, 350, and 400 are the OEM SBC offerings.
There is no such thing as a big or small block Pontiac, they are just Pontiac engines (unless you count the 301, which is the scourge of GM engines), the die hard Pontiac guys get upset if you call them big or small blocks.
Oh and you can bolt a BOP tranny to a SBC. Only two bolts line up, but I have done it on Demo Derby and Figure 8 cars (NOT RECOMMENDED).
Martin
Old Sep 17, 2003 | 12:49 PM
TheGreatJ's Avatar
Yeah yeah so I was in a hurry.....how many 267's do you see these days anyway? Even if the 383 isn't a factory combo, it's getting to be more common than the 307's and 265's and such.
Old Sep 17, 2003 | 01:23 PM
DarthIROC's Avatar
Martin
Im aware of the pontiac mid block deal, and yes I do get pissed when peple tell me they have a BB 400 (And its not a mopar)
But what about the other two BOP makes, someone was saying that the 403 is a small block and 455 is a big block in olds. Do buick and olds use diferent sized blocks.
F'n1996Z28SS
Jun 3, 2015 09:39 AM
Nellsw88
May 26, 2015 05:55 AM
geinsteder
May 6, 2015 06:02 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
