should I put a cam in...
Old Nov 16, 2003 | 06:25 PM
f-bodybuilder's Avatar
Thanks to Summit's discount table, I'm now the proud owner of a SLP 51002 cam. duration 206/212 lift .480/.487. I was thinking about throwing this into my L98, since it's still out of my car. I've got 2.73's, no torque converter, and those stock L98 heads which we all know breathe like a kid with one lung. How much of a dog is my car going to run like before i can get some mods, or even tune my ECM?
Old Nov 16, 2003 | 07:36 PM
aklim's Avatar
I'd do the intakes and insert the cam. Intakes are the biggest choke point on the L98
Old Nov 16, 2003 | 08:51 PM
12Second3rdgen's Avatar
Is that even bigger than stock?
Old Nov 16, 2003 | 09:16 PM
If you're talking about lift, stock on my L98 is .413/.428. That SLP cam is pretty much as big as I can go without having to get new parts like lifters.
Old Nov 16, 2003 | 09:22 PM
If you're talking about duration, then on my stock cam it's 202/207.
Old Nov 20, 2003 | 07:13 AM
steve10358's Avatar
3rd Gen Tech Moderator
Cam lift has no bearing on when you should buy lifters.
Old Nov 20, 2003 | 12:48 PM
Sitting Bull's Avatar
But it DOES have a direct bearing upon whether or not your stock valve springs and heads can handle that much lift.
They can't!
Your L98 heads can only cope with .460 or so for maximum lift so that cam is a paper weight until you address this issue
Old Nov 20, 2003 | 06:48 PM
aklim's Avatar
I am a cheap bastard. Therefore, I chose to buy new lifters when I upgrade a cam. I try do do what I can to avoid having to tear down the engine again and possibly have engine damage.
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Queens94z28
Nov 20, 2014 06:03 PM
