shifter help
Old Apr 21, 2003 | 10:49 AM
IROC350's Avatar
shifter help
my B&M megashifter wont shift passed reverse?? i can't see the problem so hopefully you guys have some suggestions. btw, its hasn't been used yet. ever since the cable and everything has been installed it hasn't worked...
Old Apr 21, 2003 | 04:35 PM
Jim85IROC's Avatar
You know that you have to pull up on the handle, right?
If that's not it, disconnect the cable from the shifter and see if it'll go through its full range. If not, the linkage is probably to blame. If it does work with the cable disconnected, then it could be the cable, the attachment to the trans, or the transmission itself.
blac94Z
Nov 4, 2015 01:59 PM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CARiD
Sep 7, 2015 08:21 AM
