serpentine belt question
Old Jan 12, 2005 | 03:01 PM
85MC/85GN's Avatar
i have a 88-92 f-body serpentine system on my 85 monte carlo ss. i will be putting on a underdrive crankshaft pulley, i size belt will i need? i have a a/c delete & smog pump delete pulley on it.
sometime this year i will be also putting on a caprice water pump pulley on with the underdrive crankshaft pulley, what size belt will i need for that too?
Old Jan 12, 2005 | 10:44 PM
transxtreme's Avatar
Re: serpentine belt question
Why dont u just take off the delete pullys and get the shorter belt. Thats what I did.
Old Jan 13, 2005 | 01:13 PM
95NateZ28's Avatar
Originally Posted by robvas
Check the length with a string and get one about an inch longer at the parts store
Easiest way I know how. Just make sure that the alternater is all the way in the "loose" or down position when you measure.
Old Jan 13, 2005 | 08:46 PM
anthony714's Avatar
just measure with a string like stated and go to the parts store and thell them how long u need.all those belts are the same and the part number usually corresponds to the length of the belt...also if your buying a new pulley or pulleys,the manufactors usually tell u what size or length belt u need.when i did the pulleys on my s10 it was right there,good year belt xyz....also the ac delete pulley shouldnt change your belt size cause thats kinda the purpose of the pulley is to retain the belt length and or routing
Old Jan 13, 2005 | 10:09 PM
97WS6SCharged's Avatar
Serpentine setups maintain all the accessories in a set position and use a belt tensioner. There is no "loose" position.
Old Jan 13, 2005 | 10:48 PM
95NateZ28's Avatar
Well, wrong. The 5-groove belt on my car was removed from my 1987 Z28 parts car and most certainly does not require a tensioner. The alternator is bracketed just like the "old school" setup and is what controls belt tension. The 1988-92 model years like specified by the OP probably require the tensioner. The 1987 305 Z28 does not. I originally overlooked the year in the original post.
Old Jan 13, 2005 | 11:27 PM
25THRSS's Avatar
that's because your 87 is a v belt setup
Old Jan 15, 2005 | 06:19 PM
95NateZ28's Avatar
No, it isn't. The power steering pump was v-belt driven, but the water pump and alternater were not. Just correcting the facts since someone else out there may be in the same situation.
I installed an S-10 manual steering box so I don't even have a v-belt anywhere on my running 84 Camaro.
Old Jan 15, 2005 | 09:08 PM
Very tactful response here.
Anyhow, the system used on the 87 was a hybrid between a serpentine setup and a conventional V belt setup, but is generally considered a v belt system since it uses more than a single belt and has no way to regulate belt tension.
Old Jan 19, 2005 | 10:39 AM
respectirocz's Avatar
now i'm just confused
i have an 87 iroc with a 305 4bbl, and i have 3 v belts, one for the crank w/p smog pump, one for the crank wp alt, and one for the crank wp p/s
it doesnt look anything like a hybrid serpentine system, theres no tensioner and all the belts are literally shaped like v's, not a single one has 2 or more grooves and there are no idlers, what is this hybrid serpentine system?
Old Jan 19, 2005 | 11:07 AM
Tru2Chevy's Avatar
My '87 LT LG4 had the 2 v-belts and one 5-groove belt for the alt, wp, and crank. The 5 groove is the only belt that survived the engine swap
- Justin
Old Jan 19, 2005 | 01:47 PM
anthony714's Avatar
retro,you have the old system,after 87 then went to a single belt for all the accesories..
Old Jan 19, 2005 | 03:02 PM
IROC-T's Avatar
I'm running a March power/amp pulley system on my '88 and I'm using
part#945k6 or 5060945DR,however that might be a tad short.
Old Feb 9, 2006 | 02:12 AM
damien8618's Avatar
how hard is it to swap my power steering box for a manual steering box from a 80's s10? i have a 1986 iroc z28
Old Feb 9, 2006 | 08:51 AM
- Justin
my 87 iroc with the lg4 also has v belts for p/s, a/c and smog, and a 5 groove serpentine belt for the alt, that tension is adjusted by the position of the alt
also
all belt set-ups have some way to adjust belt tension, on "v-belt" set ups it is usually adjusting the position of the accessory that is driven by the belt
with a full serpentine set up it is usually a spring loaded tensioner, but can also be as simple as an adjusting screw
Magenta_Hearts
Mar 29, 2017 08:54 PM
linz
Oct 22, 2015 07:59 AM
RUDEDOG
Parts Wanted
Apr 24, 2015 09:47 PM
grabbem88
Feb 23, 2015 09:41 PM
