Sensor question.
Old Mar 16, 2003 | 09:28 PM
SNEAKY NEIL's Avatar
Sensor question.
The 90' TBI Formula is throwing 2 codes. One deals with the barometric sensor, the other deals with the MAP sensor. I went to the local auto shop and they had both listed under 1 title. Are these two the same? Also, would a problem with these cause the car to run poorly or make it get bad gas milage? Thanks.
Old Mar 17, 2003 | 11:05 AM
Anyone?
Old Mar 17, 2003 | 11:20 AM
Aaron91RS's Avatar
Re: Sensor question.
Originally posted by SNEAKY NEIL
barometric sensor.
lmao. I have never heard it called that.
Yes it should be the same sensor.
Old Mar 17, 2003 | 11:34 AM
That's what it says in the manual..."Baro sensor", but I thought I thought the 2 were separate because of the different codes and the way they are adressed.
Old Mar 17, 2003 | 11:38 AM
Aaron91RS's Avatar
A barometer is something that senses pressure.
Your MAP sensor detects pressure(load) on the engine so I guess thats why they call it that. But I have never heard it called that in real life.
Old Mar 18, 2003 | 06:36 AM
So what happens when you have a bad map sensor?
Old Mar 18, 2003 | 12:01 PM
87DJP2001's Avatar
The Senors are the same but perform different functions. And if one is bad, most of the time the SES code will be a 33 or 34.
Old Mar 18, 2003 | 12:53 PM
Yup, both of those came up.
Old Mar 18, 2003 | 02:01 PM
Aaron91RS's Avatar
Well it's one of the most important sensors that controls spark and fuel.
One person on TG.O blew up his built engine because of this.
Old Mar 18, 2003 | 02:29 PM
87DJP2001's Avatar
Replace both Senors while your at it, they are not that expensive
About $13 each at NAPA or any other Auto Part Store.
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
zajones
Jul 30, 2015 02:18 PM
Latronaxe
Jul 20, 2015 12:00 PM
Noct
Jul 14, 2015 01:18 AM
