SBC Rear Main Seal Extender?
Old Jan 15, 2007 | 01:28 AM
Steve in Seattle's Avatar
Question SBC Rear Main Seal Extender?
While looking at gaskets for an engine build I found this interesting item:
Victor Reinz's Rear Main Seal Extender (also through CarQuest)
Issue: Many 1986 to 1996 SBC (4.3L/262ci, 5.0L/305ci, and 5.7L/350ci) experience a worn crankshaft seal area when using a 1-piece rear main seal.
Resolution: Victor Reinz now offers a rear main seal extender for late model SBC's. This seal extender may be used during an in-frame replacement or a complete engine overhaul. This patented seal extender moves the sealing lip to a new unworn surface on the crankshaft. The seal extender also prevents premature seal wear by eliminating the need for a wear sleeve on the crankshaft. Wear sleeves increase the seal deflection angle, causing accelerated seal wear. The extender is designed to fit into the back of the oil seal, making installation easy.
Application: Victor Reinz part number E-300 is available for 1986 to 1996 SBC engines.
Anyone ever used this instead of a wear sleeve?
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
carl.froehlich
Mar 13, 2015 12:38 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
