RPM Issue
Old May 14, 2004 | 02:02 PM
ping0317's Avatar
RPM Issue
Need help guys! My rpm is totally off. When I am in idle, it indicate that I am in 3500 rpm and when I start pressing the gas the rpm shoots all the way to red line. What is wrong with my car...
Old May 14, 2004 | 06:29 PM
Pneumatic_Tire's Avatar
does the engine sound like its running the rpm's read on the tach?
Old May 14, 2004 | 07:04 PM
ping0317's Avatar
my car drives really well. It is just my rpm. It is way off...
Old May 14, 2004 | 10:06 PM
TheGreatJ's Avatar
The return spring inside the tach is going bad. You need a tachometer head.
Old May 15, 2004 | 10:07 PM
aklim's Avatar
Sounds like it. ARe the gauges all advailable seperately? Also check the connections around the coil to make sure they are tight and no rust since I believe that is where the signal is coming from for the tach.
Old May 16, 2004 | 02:43 PM
ping0317's Avatar
thanks I will check it out
timmy39120
May 8, 2015 11:41 AM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
Cam's maro
Mar 24, 2015 08:09 PM
edman
Mar 13, 2015 09:39 PM
derty
Jul 16, 2002 12:20 PM
