rough idle, stalling
Old Sep 13, 2002 | 11:01 AM
spyro_ss's Avatar
Post rough idle, stalling
I just got the 305 TPI in my '86 IROC replaced with a Jasper Class 2 performance 350 including a hypertech thermomaster chip, 26# injectors, new accel distributor & coil, new EGR valve, new catalytic converter, new IAC. It runs great, but idles very rough and stalls if not in neutral or foot on the gas & brake at the same time. It will crank but won't start when hot. The shop that installed it can't figure ot out.
Old Sep 13, 2002 | 12:18 PM
aklim's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by spyro_ss:
Jasper Class 2 performance 350 including a hypertech thermomaster chip, 26# injectors</font>
Maybe here's the issue. What was the chip for? You are out of the point where it will work. I can't remember what 305s came with but 350s came with 22 pph injectors. If your Hypertech was set for 305, there would be a definate problem. If it is set for 350, it would still be a problem. The ECM was told that it had 22 pph injectors and it has determined that a certain pulsewidth for those conditions based on 22pph. You have increased it by 18.18% (26-22)/22 is the equation. You will have to switch back to 22 pph or get a custom eprom to get it running right. Feel free to ask Eileen Formato at www.fasterproms.com for her opinion. They will custom one for $500. It will be roughly set to your specs then you datalog it and send the file to them. Takes a couple of burns till they get it just right. If you make major mods in the future like a set of heads, different cam, induction, etc (not thermostat or new coil) it costs $150 for them to get it right again. I have used their service and liked it.
Old Sep 13, 2002 | 07:21 PM
ws6gta's Avatar
Post
i believe the 305 had 19lb. he's right the injectors are to big for the hypertech chip you have.
Old Sep 23, 2002 | 07:52 AM
spyro_ss's Avatar
I finally got some time yesterday, so I put in the old fuel injectors (19#) just to see if I could get it to idle properly. The was no change in the idle, so injector size doesn't appear to be it. Any other suggestions?
markzzzz
May 8, 2015 09:21 AM
Fatdog2
Feb 13, 2015 08:19 PM
Iamherefornow
Jan 26, 2015 04:57 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
TrouserSnake
Jul 29, 2002 11:24 PM
