Rough Idle
Old Sep 16, 2007 | 08:52 AM
mrcamaro1956's Avatar
Rough Idle
Hi,i Have A 1992 Camaro Rs 305 Tbi The Problem Iam Having Is The Idle On It Is Surging.when I Stop At A Red Light Or Slow Down The Idle Goes So Low The Engine Turns Off,this Happens Also When I Put It In Drive . I Have No Codes Or Check Engine Light,the Timing Is Set To 0 Degrees Tdc This Is Getting Anoying Please Help
Thank You
Old Sep 17, 2007 | 09:56 AM
Rice Killer87's Avatar
Timing shouldnt be at 0,shoulbe be around 6-8*.
Sounds like a vacuum leak to me.
Old Sep 17, 2007 | 04:32 PM
the timing lable on the hood says o degrees tdc
Old Sep 17, 2007 | 07:50 PM
jstud's Avatar
im having the same problem with my 1991 rs 305..i belive mine is with IAC if you have any luck pm me lol
Old Sep 17, 2007 | 08:20 PM
1987IROC350's Avatar
This is a link that has a similar issue that turned out to be the in tank fuel pump. This does seem to be a hard prob. to solve.
http://www.thirdgen.org/techboard/tb...help-idle.html
Old Sep 18, 2007 | 12:36 PM
Also My Spark Plugs Are Black With Carbon What Can Cause This
Old Sep 18, 2007 | 05:10 PM
jstud's Avatar
too much fuel or old plugs when i changed mine they were nasty black...any luck so far? im still tracking wires on mine looking for a kink or break
also not to thead jack...does anyone have a wiring diagram?
Boss002
Jan 20, 2016 12:17 PM
Firechicken350
Aug 30, 2015 06:59 AM
michaelzilinski
Jul 31, 2015 08:41 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
