rough idle
Old Dec 10, 2005 | 01:04 AM
theredone's Avatar
rough idle
would removing the air system and cat change the way the car runs
its a 1988 camaro iroz 350 tpi.
I have rough idle, hesitation, flucuation in the idle up and down from 600 to 1500 rpm sometimes not always
tps and iac are fine, o2 sensor may be old.
fuel pressure at 30psi key on and 41-45 psi at idle
new egr system
brand new rebuilt motor
Old Dec 10, 2005 | 09:57 AM
stubbs's Avatar
Re: rough idle
I had the exact same problems, turned out to be 2 things. 1st my bellows had a small crack in the bottom that was leaking in air after the MAF so the car was stumbling real bad, because you say you sometimes have this problem I would check your intake for leaks, the O2 sensor reads the lean condition and adds fuel for the air leak, which would explain it coming and going, but then I would get an occasional backfire, but I have no cats so its easy for it to backfire. My other problem was that I lived in a dusty area and my MAF was a little screwed up, I tried a new burn off relay, and it did nothing, so I wanted to clean the wire on the MAF, well after about 25 people telling me exact conflicting info on how to clean it and that I would ruin it if I did it the other way(all directly conflicting each other) I just bought a new one. All my problems are gone now.
Old Dec 12, 2005 | 12:57 AM
theredone's Avatar
Re: rough idle
i also have poor mileage
Old Dec 12, 2005 | 06:37 AM
89_Irocz's Avatar
Re: rough idle
Have you tried a simple tune up?
Boss002
Jan 20, 2016 12:17 PM
Firechicken350
Aug 30, 2015 06:59 AM
michaelzilinski
Jul 31, 2015 08:41 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
