Roller Rockers
Old Feb 26, 2004 | 03:47 PM
irocz2804's Avatar
Roller Rockers
I was just curious if some roller rockers off a chevy 283 would fit on my 305....i think that the valve covers are center bolt....thanks in advance for any help...
Old Feb 26, 2004 | 04:32 PM
Rice Killer87's Avatar
as long as the stud on both heads is 7/16 (which it should be) than it will work.
Old Feb 26, 2004 | 05:17 PM
irocz2804's Avatar
ok man thank you...i will check things out and see how they all turn out
Old Feb 26, 2004 | 05:59 PM
TheGreatJ's Avatar
If you do have centerbolt valve covers then the rocker body may not clear the webbing in the valve covers. Centerbolt heads usually require narrow body roller rockers.
Old Feb 26, 2004 | 07:07 PM
greezemonkey's Avatar
And most times you need a steel guide plate, but it can be done without if you use self guided rockers
Old Feb 26, 2004 | 07:09 PM
TheGreatJ's Avatar
True....and the odds of rockers on a 283 being self-aligning are pretty slim. If there are guideplates on the 283 be sure to get them too.
Either way, if they won't fit your 305 and you need to sell them cheap....email me.
Old Feb 26, 2004 | 10:29 PM
aklim's Avatar
Re: Roller Rockers
A 283 sounds too old to have centerbolt so it would probably not fit without modifying the VC. I know LPE sells modified VC for using the perimeter bolt VC. So either modify your VC or get the Crane Narrow body RR.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
