Reverse Light not working Need Help
Old Jan 18, 2003 | 08:50 AM
KarmaCult's Avatar
its dense fog right now in northern California, but I still had to goto work, and thats when I noticed it, when I back out, of course, I put it into reverse, and theres no lights, like if I put it in half way, the lights come on, but if I just let it drop all the way down the 'shift' the lights turn off, let me try to show you
ok, heres the 5th and R shift points:
|- (N)
| (if I shift here, only half way, there is reverse lights)
R (If I shift to here, no reverse lights)
Can someone help? I can't just stick it in half way into gear, as I have to hold it, or it will go all the way into gear, which means the lights turn off.
Help
-Karma
Old Jan 18, 2003 | 03:48 PM
I EAT T/A's Avatar
I had the same problem with my '91Z automatic, if the shifter was closer to park the lights would stay on.
I'm guessing its from wear that the sensor moves or wears off. I'm not sure.....
I don't have that problem with my 5speed now.
Old Jan 18, 2003 | 08:51 PM
aklim's Avatar
On the A4 there is a slide that moves when the shift lever moves. That is adjustable so there may be something like that for you to adjust.
Old Jan 19, 2003 | 03:18 AM
stonedchihuahua's Avatar
On my t-5 the plug for the cable is loose so teh movement of the shifter will make the lights flash on then off agian... check that out if so get a new one or bend the pins a bit
Old Jan 19, 2003 | 03:56 AM
KarmaCult's Avatar
How do I check/fix it?
How do I check it?
I havent really messed around with my tranny before, I have with an auto, but not a manual, I figure they are differant....
So what all should I check?
and how?
Much thanks guys,
-Karma
squarehead
Jan 15, 2015 07:02 PM
Collector Car
Jan 5, 2015 10:58 AM
fpete1992
Dec 11, 2014 03:51 PM
A's 91 Z28
Dec 7, 2014 12:09 PM
siguy
Nov 27, 2014 10:07 AM
