compression test on motor outside of car
Old Jan 19, 2003 | 02:40 AM
Smokeyz28's Avatar
how hard is it to do a compression test on an engine outside of a car?
my buddy is selling his early 80s sbc 305 for $450 CDN. it has been rebuilt with new pistons, lumpey cam, hard top valves (i think thats what it is).. it just needs a carb, but i can use mine..
so he's bringing it over on monday, and i wanna know what i need to do a compression test to make sure he aint ****ting me about being like new. what should a new motor push out for psi?
Old Jan 19, 2003 | 03:20 AM
stonedchihuahua's Avatar
Umm you need something to turn over the crank and a stand to hold the engine (do not use a pipe wrench on the end of the crank, so dink did that to my 400 crank) Also I believe the compression from the factory was 9.5:1
Old Jan 19, 2003 | 08:25 AM
ZZ430RS's Avatar
It's easy to do on a chevy if it has a flywheel on it as the starter bolts to the engine, I've done it using jumper cables and a wire to engage the solenoid, hard to tell about what the compression should be as the cam affects what it will be, should be 130-190 psi, biggest thing is to have all the cylinder close to the same, if 1 or 2 cyl. are a lot lower than the rest you know you have a major problem. Make sure if it has carb. to block it open when you check so it will get enough air
LeftoverChinese
Jan 14, 2024 03:03 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
naaz90
Jul 27, 2002 08:22 AM
