Removal of Charcoal Canister
Old Dec 28, 2003 | 10:48 PM
shwine617's Avatar
I need some step by step instructions or tips on how to remove the charcoal canister from my car. I am dropping the tank to do a fuel pump so i think i can remove the vent lines while I am at it, and advice would be great.
thanks!
Old Dec 29, 2003 | 01:00 AM
90rocz's Avatar
Remove the vent lines? What about "vapor lock", a condition of vacuum in the fuel system resulting in fuel flow resistence.
Why remove them? I the cainster is in the way, relocate it...
Old Dec 29, 2003 | 09:58 AM
aklim's Avatar
I'd leave everything where it is. If you want to remove the canister then just remove it and plug up everything it goes to. That is what I did. I also let the tube from the tank come into the engine compartment and vent into the atmosphere.
Old Dec 29, 2003 | 10:37 AM
RobsWS6's Avatar
Yep, just take it out and vent it to atomsphere. You might notice a fuel smell at first. You could smell mine if you were leaning into the engine compartment. But it only did it for a couple months or so. At least I can't smell it now
Old Dec 29, 2003 | 07:01 PM
aklim's Avatar
Really? Never could smell it at all but that is me.
Old Dec 29, 2003 | 09:28 PM
shwine617's Avatar
which lines do you plug? and you only vent the one to the throttle body? also can i relocate the vent line to under the car?
thanks
Old Dec 30, 2003 | 12:25 AM
Ace_437's Avatar
Why do you want to get rid of it?
Old Dec 30, 2003 | 08:45 PM
aklim's Avatar
There is a long line that seems to come from the back of the car. That is the one you plug off, if you must. I just vent it.
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
