Recommended Carburetor?
Old Apr 6, 2006 | 05:39 PM
Mason's Avatar
I have an '89 Z28 with a 350 in it, and it still has the stock carburetor. I wanted some opinions on which aftermarket carburetor I should buy. I'm not looking for anything way too expensive, but for a reasonable price, I was wondering which performance carburetor would be the best for my car.
Thanks for the help,
Mason
Old Apr 6, 2006 | 08:10 PM
conlinj's Avatar
Re: Recommended Carburetor?
It really depends on the rest of the setup, What cam and heads are you running? If it's stock a 570cfm holley street avenger or 600cfm edelbrock would be fine. If you plan on doing anything to it, or it's a mild street/strip motor a 670 holley street avenger or a 650cfm edelbrock would be perfect. I personally like the Holley's more then the edelbrock's but the choice is yours there.
-Jim
Old Apr 7, 2006 | 03:05 PM
Mason's Avatar
Great, thanks. When I get around to buying it I'll probably go with the 670 Holley.
Thanks again.
Old Apr 7, 2006 | 06:13 PM
conlinj's Avatar
Thanks again.
I have the 670 on my 350 I love it, big difference over the edelbrock I had.
-Jim
Old Apr 7, 2006 | 06:39 PM
LameRandomName's Avatar
If you like tinkering with the carb for different conditionsm use an Edelbrock, which is basically a Carter AFB. If not, use a Holley. In both cases you want 750 cfm, and stay away from mechanical secondaries. Beyond that, just shop around. You can also consider a used one with a rebuild kit. You can buy this carb cleaner setup at an autoparts store. It's a bucket of cleaner with a sort of collander thing with a handle that lets you dunk the parts.
Old Apr 7, 2006 | 06:51 PM
conlinj's Avatar
750 cfm?? Hope he has alot of cam and heads...
Old Apr 8, 2006 | 09:44 AM
Chrome383Z's Avatar
Don't get the 670, just get a nice 650 VS and put the quick spring change kit in - MUCH CHEAPER. And it's the same thing. Holley is making $$$ on the 670 thanks to their marketing department - NOT their engineering department as it's the same carb.
Old Apr 8, 2006 | 10:30 AM
conlinj's Avatar
I got mine for 100 dollars
Jeff1904
Jun 5, 2016 05:00 PM
surreybrad
Sep 29, 2015 09:00 PM
Beave2780
Sep 23, 2015 12:37 PM
tommalcolm
Sep 11, 2015 03:39 PM
zFrank
Aug 12, 2015 03:46 AM
