Recharging AC- where are the high and low lines?
Old May 9, 2004 | 09:43 AM
firebirdjosh's Avatar
I am doing the retrofit kit and I don't know where to high and low AC lines are in my V6 firebird. Can someone help me? Thanks!
Old May 9, 2004 | 10:40 AM
Stephen 87 IROC's Avatar
High side is the pressure side. It starts at the compressor port marked P (pressure), goes through the condensor in front of the rad then to the accumulator (big shiny cylinder) then into the firewall. The low side is the hose that comes from the firewall back to the compressor port marked S (suction)
Or do I have that the other way around?
Old May 9, 2004 | 01:25 PM
When I push the pin on the high side, some air leaks out. Does that mean I am not out of Freon? Also, what is the capacity for the third gens? I have 3 cans of Suva.
Old May 9, 2004 | 02:00 PM
I mad a mistake. I went and looked at my system. The accumulator is on the low side.
From the firewall to the accumulator to the S port on the compressor is all low side. The high side comes from the P port on the compressor, through the condensor in front of the rad then to the firewall. The access port at the compressor is on the high side. The port on or near the accumulator is the low side.
Unless your system is completely empty, there will always be a little bit of pressure in the system even on the low side.
There should be a label somewhere saving how much freon is in the system. My truck was 2.2 pounds of R12. I only put in 2 pounds of R134A since you have to put in something like 80% of the R12 charge.
Old May 9, 2004 | 02:33 PM
Yeah, it said 2.25 lbs. Thanks alot. Its all charged and is blowing ice cold. THe thing that is odd is that the cans didn't empty all the way so i took them off and had that stuff shooting everywhere!
Old May 9, 2004 | 07:24 PM
Kwiksilverz28's Avatar
You opened the cans and they equalized pressure with the system, then you closed the cans and removed them. They had the exact same pressure as the system after you removed it. :-)
Old May 9, 2004 | 08:03 PM
buzz12586's Avatar
How hard is it to recharge you AC system??? I really wanna do this but I don't know if I wanna spend $30 to have someone do it.
Old May 11, 2004 | 02:03 PM
Thats exactly what I thouht but the directions didn';t mention that at all and it seems dangerous to not even say anything.
It took me about 20 minutes and the whole time was just waiting for it to equalize, so I reccomend doing it yourself. I tried it today, it was nice!
carl.froehlich
Mar 13, 2015 12:38 AM
Jan 23, 2015 01:13 PM
My94RedZ28A4
Aug 11, 2002 10:04 PM
funina91ss
Aug 6, 2002 11:20 PM
