rebuilding a 700r4 yourself
Old Feb 11, 2003 | 08:40 PM
  #16
aklim's Avatar
I'm sure the DS length isn't constant so that would need to be changed but if you can get the right bellhousing, that part should bolt up. Not sure about the kickdown cable and shifter linkage. Why are you going that route when you can rebuild your 700 R4 and have it fit right in?
Old Feb 11, 2003 | 08:52 PM
  #17
brodyscamaro's Avatar
you need a new crossmember and torque converter. also speedo work might be needed. spohn sells a kit that has everything IIRC
Old Feb 11, 2003 | 08:53 PM
  #18
TheGreatJ's Avatar
To go to a Turbo 400 you need the tranny, torque convertor, a custom crossmember, driveshaft, new shifter, and then you still have to figure out something to do about the torque arm. You'll probably have to go aftermarket on it which can be VERY pricey.
All in all it's not worth it unless you're building a flat-out drag car and need the trans to be good for 700hp or something.
Old Feb 11, 2003 | 09:28 PM
  #19
StealthElephant's Avatar
Yea, so basically a T56/T400 is out of the question...too much custom work for me, too much cost.
I'm satisfied though, I've pretty convinced that a strong 700R4 will be fine.
Thanks for all the great info as always
Old Feb 12, 2003 | 04:03 AM
  #20
Pro Built Automatics's Avatar
camarocruzin, it can come with instuctions on how to do this at no extra cost, just ask.
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Ks0209
Oct 1, 2015 07:32 AM
Bxlt1
Sep 29, 2015 03:18 PM
Jake Bialke
Sep 24, 2015 11:31 AM
