Front Spring Replacement
Old Feb 10, 2003 | 01:02 PM
rudy's Avatar
Question Front Spring Replacement
So I am changing the front springs on my car (again) and installing some suspension technicques lowering units. Problem is, how do you index the spring in the lower control arm? I can't see any stop to locate the bottom. Any ideas?? Been a while since I did this, and just can't seem to remember the last time.
Old Feb 11, 2003 | 10:14 PM
Matt87GTA's Avatar
Arrow
There is a hole in the pocket for the spring that has a little more of a dip in it that is where the end of the last coil should reside. I forget exactly where it is supposed to be in regards to the direction the spring should point, but if you do a search on the suspension board at thirdgen.org you should be able to find some pics of this as I know I have seen this exact question come up.
Old Feb 12, 2003 | 06:17 AM
rudy's Avatar
THanks, I will give it a try.
Jazsun
Dec 29, 2014 12:14 PM
ModdedNerd
Dec 25, 2014 05:51 PM
Hurin
Dec 13, 2014 07:38 PM
