Rear Ends
Old Mar 8, 2003 | 12:39 AM
AndrewC's Avatar
Rear Ends
Anyone having opions on rear ends for 3 gen 83 z28, I'd like to hear from you. I currently have about 500 hp +/- running into it. My rear end is stock 3.73 posi. I have been told that the c clip rear end can break and cause a big problem. Most people say go right to 9" ford. I like to just for the tub job. Anyone make a factory replacement ford diff for our 3 gen's????
Thanks all
Old Mar 8, 2003 | 04:29 PM
Aaron91RS's Avatar
You can get converted 9inches or 12 bolts. They are both over $1500.
I run a 9bolt because it's cheaper.
Then again. If it ain't broke, don't fix it.
Old Mar 8, 2003 | 04:55 PM
mr diabolical's Avatar
any rear that will mount up in a 4th or 3rd gen will work in your car. so getting a 12 bolt or 9 inch is a couple of options. i just run a 4th gen 10 bolt with a heavy duty posi and its been fine.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
