rear ends???
Old Jan 25, 2004 | 07:03 PM
  #16
stanghunter211's Avatar
An 89 would have the PBR brakes which look different from your fronts. They are finned and alot wider looking. They stopped putting 9 bolts in cars in 90. After that they went to 10 bolts again. So you can probably find a Borg Warner rear end from 87-90. MAAAAAAAYBE an 86 here and there, the ones that came out late in the year. The 3.45 disc rear is the most rare and you would be hard pressed to find one laying around. 2.77 an 3.27 are fairly common with the 2.77 being the least popular.
Will
Old Jan 25, 2004 | 07:11 PM
  #17
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Will
The one that I got is a 3.45, but its not an 89
Old Jan 25, 2004 | 07:13 PM
  #18
8_4_berlinetta_'s Avatar
how will i know whats the gear ratio??
Old Jan 25, 2004 | 07:20 PM
  #19
If you are pulling it out of a stock car, check the glovebox and look for the RPO for that gear.
GH3=2.77
GW6=3.27
GM3=3.45
Check the rear end cover too, there should be two tags one for limited slip fluid and the other reads the axle code right on it. But that could have been tampered with. Its anyones guess really, unless you wanna take the cover off and look in there and count the teeth and then spin to find out how many times it actually rotates. Keep in mind while you are doing all this, BW stuff is not easy to come by, as far as replacements go. Gears too, if you ever get unhappy with em, and wanna upgrade, you don't have many options. Its not like a 10 or 12 bolt where you can get anything you want. Not saying they aren't super rearends, just a little on the rare side all around and since they were only in production on 3rd gens for like 4 years, its not wonder they never made any aftermarket parts or that many upgrades/replacements
Will
Old Jan 25, 2004 | 07:25 PM
  #20
l98 thats only in irocs right?
Old Jan 25, 2004 | 07:34 PM
  #21
angel71rs's Avatar
T/A's and Formulas too.
  #22
Not necessarily.
The L98 was available from 87-92 so that means that in
87 it was available in the Z28 and IROC
88-90 only the iroc since there was no Z28
91-92 the Z28 since there was no more IROC
The same years apply for Firebirds, though I am not as knowledgeable about their varients
you will not find a 3.45 rear in a L98, they never produced it. It was intended for the LB9 305 TPI cars with a 5-speed manual. Now it will bolt up just fine, but if you find it on a 350 car, its not from the factory. The only rear gears you will find on a 350 BW 9 bolt are 2.77 and 3.27. Cars with the 3.27 ratio usually got more options like dual cats when it was an option back then. That might help you in you're search.
I am stressing finding a 89-90 one becaus they have better brakes. You can get a 87 if you find it, like i did, but the brakes suck and will have to be changed. And if you are swapping from a car, your car, which has drums out back, you will need a new prop valve. Get the one for your year car, but for the brakes that you are gonna use. Make sure it is for you year car to cancel out any install probs
Will
Old Jan 25, 2004 | 07:46 PM
  #23
ok so im looking for a 89 iroc and i need a prop valve for disc brakes. you said get for my car so i need a prop valve for a 84...
did they have disc brakes back then??
Old Jan 25, 2004 | 07:51 PM
  #24
Yes, sure did. They had discs since 82, although it was a pretty rare option
Will
Old Jan 25, 2004 | 07:54 PM
  #25
ok thanks for all the help
Old Jan 25, 2004 | 07:55 PM
  #26
YOU BET. Good luck to ya. Let us know how the hunt turns out
Will
Old Jan 25, 2004 | 07:57 PM
  #27
alright might be awhile though still working on puttin everything back together plus my rear end is fine as of now just wondering for the future
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
