Rear end help
Old Feb 19, 2004 | 11:45 AM
1984camaroz28's Avatar
Rear end help
Not shure what to do with my rear when i bought my 84 as a roller it already had 4:10s when i had my small black in it (around 425hp) the rear held up. now that i went big block im not shure that its gona hold up long.... I dont wana buy a 9in or 12bolt i just dont have 2500$. Is there anyway to build my 10 bolt up
Old Feb 19, 2004 | 12:16 PM
and is it a 7.5 or 8.5 that came in 1984 z28 h.o cars... also what spline axels can i run
Old Feb 19, 2004 | 01:50 PM
Z28SORR's Avatar
As i see it you have only one option. Drive with a very light foot until you have saved enough for the 9" or 12 bolt.
aklim's Avatar
26 spline. You can put a cover to support the end caps, chage the fluid as you should. Also put in a posi and stronger axels if you need them.
Old Feb 19, 2004 | 02:43 PM
Marc 85Z28's Avatar
Your rear is a 7.5" 10 bolt with 26 spline axles. However, all parts are interchangable with the later 7 5/8" 26 spline axles and 7 5/8" 28 spline axles.
You can build them to support decent power, regardless of what others say. Follow this buildup: http://www.ws6transam.org/10bolt.html
Or, if you're BB is making a good bit of torque and you've got a high stall converter and sticky tires the 9 bolt that came in the mid-late 80s F-Bodies would be an excellent alternative. They are significantly stronger than a built 10 bolt. And although parts prices for the 9 bolt are more expensive than the 10 bolts, its still much cheaper than a 9" or 12 bolt.
Old Feb 19, 2004 | 09:46 PM
carcrazyQT's Avatar
Just how much horsepower can those 28 spine axels handle anyway? Does anyone know?
Old Feb 20, 2004 | 01:22 AM
aklim's Avatar
I believe it can easily handle 500 HP on an A4. Now on a M5 where you drop the clutch at 5000, that might be a little different.
Old Feb 20, 2004 | 08:00 AM
it a Th400
Old Feb 20, 2004 | 10:19 AM
aklim's Avatar
Doesn't matter. The thing is that with a stick, when you launch, you might drop the clutch at 5000 rpm or whatever and you shock the system more than if with an A4, or A3 in your case, you probably will launch at about 2000 or so.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
