rear end
Old Jul 6, 2004 | 04:04 PM
durtybird's Avatar
Question rear end
can i put a 4th genereration rear end in a 3rd genereration easily
Old Jul 6, 2004 | 07:57 PM
aklim's Avatar
I thought the length is not correct in that it is too long. So, what is your defination of "easily"?
Old Jul 6, 2004 | 08:28 PM
Stephen 87 IROC's Avatar
It's a direct bolt in however a fourth gen diff is 2" longer on each side so you either need to use fourth gen rims, buy some rims with more backspace or live with your tires sticking out of the fenders an extra 2".
Old Jul 6, 2004 | 10:46 PM
durtybird's Avatar
easy as bolt right in and ill prolly get rims off a 4th gen
Old Jul 7, 2004 | 01:23 AM
Zepher's Avatar
If you use the front/rear offset 16" 3rd gen wheels, it will look a little better. If you have 15's or other sizes that are the same offset for the front and rear, the rear will stick out noticably.
Here is my Formula with rear offset 16" GTA wheels with an LS1 rear off of a 98 Firebird,
And this is what a non-rear offset wheel sits like,
Old Jul 8, 2004 | 04:06 PM
Marc 85Z28's Avatar
93-97 4th gen rears are almost 4" wider than you're 3rd gen rear. The later 98-02 rears are just over 3" wider than your rear. Regardless of width, all suspension locations and provisions are the same. If converting to a rear disc setup, you will need e-brake cables for an 89-92 car with the PBR rear discs.
Old Jul 10, 2004 | 09:29 PM
quickchicken's Avatar
Zepher, the pics of your formula. was that reg rear offsets with a 4th gen rear? or was that front offsets on a 4th gen rear?
Old Jul 11, 2004 | 02:57 PM
Zepher's Avatar
Those are rear offset wheels on the 4th gen rear.
Old Jul 11, 2004 | 03:10 PM
ok, thanx. is this a pic of fronts on a 4th gen?
http://www.transamws6.com/pics/4th_gen_rear.jpg
Old Jul 11, 2004 | 04:16 PM
Zepher, whats the widest tire you can safely run with front ofsets on the rear?
Old Jul 11, 2004 | 06:41 PM
Zepher's Avatar
I was running 255/50/16's and they fit fine,
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
