Rear Brake Lights in Spoiler All Out
Old Nov 7, 2003 | 05:35 PM
Tom87IROC's Avatar
I've had a light bulb here and there go out, but never the entire row. Is this common? Does it indicate a problem other than bad bulbs? I'm not sure if they went out together or one by one. I never get to see it from the rear because I'm always in the driver's seat.
Old Nov 7, 2003 | 07:21 PM
Z28James's Avatar
Mine dont work either, checked all the connections i could find but it still doesnt work. i hate wiring :/
Old Nov 7, 2003 | 07:45 PM
MasterEvilAce's Avatar
i had sort of a weird problem
it all had to do with the connections to the lights
the connections were pretty dirty, and the lights didn't make good contact. i bent the light's metal connectors, to make them stick outward (push against the metal)
and it seemed to work, after a few tries
if they all went out.. uhh.. not sure what to tell you
i THINK one bulb would cause the rest of them to go out ie:
1, 2, 3, 4, 5 (or however many bulbs)
if #2 went out, 1 would work, 3 4 and 5 would go out with #2
despite it looking like the connections were in PARALLEL.. which is just weird
just play with it a bit.. that's how i got it working.
Old Nov 7, 2003 | 10:25 PM
87DJP2001's Avatar
If you installed the Halogen Bulbs with your bare fingers, it will result in early bulb burnout. Common occurance with this type of handling.
Old Nov 16, 2003 | 08:15 PM
Tom87IROC's Avatar
I'm still having problems with the rear center brake light. The whole strip is still out and I just replaced every bulb. My hatch pull down is not connected right now. Is the hatch pull down and the center brake wired through together? I'm getting a rebuild kit for my hatch pull down and cannot connect it up until I finish the rebuild. I was wondering if I should be looking somewhere else for my problem.
Old Nov 16, 2003 | 09:20 PM
Dave89IROC's Avatar
the third brake light is powered through the outside terminals of the 4 contact thing to the left of the latch, is it still in your car?, try cleaning the contacts, i used a screwdriver on the bodyside and a wire brush on the hatch side
CARiD
Feb 9, 2015 09:35 AM
squarehead
Jan 15, 2015 07:02 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
